tach output?
Old Sep 7, 2006 | 02:53 PM
andypz28's Avatar
Default tach output?
on the MSD window switch, where does the white wire connect to?
does it go straight to the pcm? or do i need the a relay for the tach output?
Old Sep 7, 2006 | 02:55 PM
turbo86's Avatar
Merry Christmas....
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_wiring
Scroll up to the PCM PinOut wiring diagram. Its the RED PCM connector, where the Tach output is located.
Old Sep 7, 2006 | 03:31 PM
jldak318's Avatar
pin 13 its a white wire if im not mistaken
Old Sep 7, 2006 | 03:32 PM
jldak318's Avatar
Originally Posted by turbo86
Merry Christmas....
thats for a lt1, he has an ls1.
Old Sep 7, 2006 | 04:52 PM
WS6HUMMER's Avatar
Straight to the PCM, for 99 model cars its pin 10 on the red plug, white wire I think. 2002's may be different.
Old Sep 7, 2006 | 04:57 PM
WS6HUMMER's Avatar
Here's your answer for sure.
http://www.ls2.com/boggs/torques/2002pcm.htm
I was right.
Old Sep 7, 2006 | 07:23 PM
andypz28's Avatar
awesome, thank you!
Old Sep 8, 2006 | 03:52 PM
andypz28's Avatar
so its the white wire to the PCM but is it pin 10 or pin 13???
Old Sep 8, 2006 | 04:09 PM
WS6HUMMER's Avatar
Its pin #10 which is a white wire on the red plug. Again look at this link I posted for you, it has all the pin locations for the PCM and where they go.
Old Sep 8, 2006 | 04:15 PM
andypz28's Avatar
awesome, thank you.
i looked at the chart but got confused
Old Sep 8, 2006 | 04:23 PM
WS6HUMMER's Avatar
awesome, thank you.
Do you understand it now? If not scroll down to the second chart, that's the one for the red plug pin-out.
Old Sep 8, 2006 | 04:28 PM
andypz28's Avatar
i get it now, the engine speed one right?
Old Sep 8, 2006 | 04:32 PM
WS6HUMMER's Avatar
That's it
Old Sep 11, 2006 | 11:47 PM
andypz28's Avatar
what do you mean by red plug?
the pcm has a grey cover and then has the wires. spliced window switch to pin 10 white wire and it didnt work.
Old Sep 12, 2006 | 02:02 PM
andypz28's Avatar
also, spoke with local msd, they're saying i need something to convert the tach signal from the pcm to to the window switch.
i forgot the part number but its an MSD product to convert it.
tried wiring to pcm directly but it did not work.
Old Sep 12, 2006 | 04:31 PM
jldak318's Avatar
yes it is pin 10, sorry for the misinformation.
Old Sep 12, 2006 | 06:53 PM
andypz28's Avatar
pin 10 didnt work... :\
Old Sep 12, 2006 | 07:10 PM
Hennytime's Avatar
if you tae the harness off the ecu/pcm there is a blue plug, and a red plug, get to the red plug and then find the number 10 wire, its on the end not in the middle, and i believe when i did my install, it was a white wire, and did this on a 2002 z28
Old Sep 12, 2006 | 09:18 PM
andypz28's Avatar
i took off the grey covers but i did not see any plugs...
will try again tomorrow in the day light tho
