should I ????
Old Sep 10, 2006 | 11:56 AM
chris2000ss's Avatar
Default should I ????
well,I finally got my nitrous all hooked up.
1.NOS 5177 kit (100 shot for now )
2.MSD window switch
3.SVO 42lb injectors
4.TR-6 plugs
5.purge kit
the only thing I didnt install yet is my Racetronix PnP pump.My question is i'm itching to take her out and spray some juice threw her now without installing the pump.Would you take it for a test spray or would you install the fuel pump ?????
Old Sep 10, 2006 | 01:03 PM
come on guys i'm wanting to take this bitch out ASAP think i'll be all right on the 100 shot ?? I know the safe thing to do is install the pump but I want to feel the juice LOL...
Old Sep 10, 2006 | 01:12 PM
andypz28's Avatar
go for it, i have the same kit and im spraying a 100 shot w/ stock injectors and fuel pump...
Old Sep 10, 2006 | 01:30 PM
Blk97WS6's Avatar
yea you will be fine. i dont even think those injectors are needed.
Old Sep 10, 2006 | 01:34 PM
Brian2006's Avatar
Same here. i have the exact same setup with stock injectors and fuel pump. Been thru 4 bottles and haven't had a bit of problems yet.
Old Sep 10, 2006 | 02:06 PM
Brian2006's Avatar
Old Sep 10, 2006 | 03:53 PM
thanks guys I'm going to spray it today i'll post back soon...
Old Sep 10, 2006 | 04:09 PM
Robert56's Avatar
Spray it, you'll be fine, unless you have a real weak stock pump. after your pump install, then going big or stay home will apply.
Robert
Old Sep 10, 2006 | 04:14 PM
mrr23's Avatar
i don't see where he reprogrammed the computer for the larger injectors. should run like crap. in his sig, it says hptuners. so, maybe he did.
Old Sep 10, 2006 | 04:19 PM
Robert56's Avatar
I think his sig states HP Tuners, so we assume that this has been done, and an easy tune item to do.
Robert
Old Sep 10, 2006 | 04:24 PM
mrr23's Avatar
his sig also states he's at 414 rwhp now with what he has NA. now, with all of the rumors of a stock pump not supporting past 480 rwhp in an f-body, then why tell him it's ok to run the dry shot with a stock pump? 414 + 100 = 514 rwhp.
personally, i've been to 481 rwhp with no drop on the a/f ratio on a dyno in third gear (auto). but, mine are wet kits.
Old Sep 10, 2006 | 07:55 PM
Robert56's Avatar
The 5177 100 shot is really 85rwhp, so 414 and 85 is 499rwhp, so I still maintain he is fine, if stock pump is working properly. I think he is just wanting to spray "now" and will put pump in soon after. 500rwhp has allways been the safe max for f-bods and 550 for y-bods concerning good stock pumps. Many certainly have gone past these bench marks. Monitor the fuel pressure if ya can, and if ya see it dropping then your outa pump, or watch a/f to see if going lean at highest demand, both will tell the story.
By the way, you stated:
. Now what does running a wet kit tell you? if you are running out of pump dry, then you will also run out of pump wet.
Robert
Old Sep 10, 2006 | 08:10 PM
thanks for the replys guys.I didnt get to spray it I had to take the wife and kids for a ride instead..but theres always tomorrow
I did tune for the injectors..
Old Sep 10, 2006 | 08:33 PM
mrr23's Avatar
my point was about the rumors of 'about' 480 rwhp being the max for a fbody. apparently, it's not the limitation the rumor that goes around says it is. that's my point.
