need help asap! nitro dave window switch!!
Old Sep 10, 2006 | 04:33 PM
CamaroSS621's Avatar
Default need help asap! nitro dave window switch!!
trying to wire up the window switch in a 02 Z06. Where to I hookup the tach/rpm tire and where do I connect to the TPS wires??? ALso, does the yellow wire go to the relay for the arming system??????? thanks guys! pics would REALLY help.
PS: where is the best place to mount it??
Old Sep 10, 2006 | 08:11 PM
Robert56's Avatar
If this is the dual stage "Trick" ws, then do a search for 00vette, as we just did an install of this sw. The directions are a little confusing, but the thread clears the way and you should be able to do fine. If ya can't find it let me know. There is also a wiring post in the stickies, but the setting for tach is indicated wrong in the post other than that it's fine as far as I can tell.
Robert
Old Sep 10, 2006 | 08:15 PM
Beer99C5's Avatar
I have pics of where Vinny at 860 Performance hooked mine up in the wiring sticky.
Been meaning to check how it is set (00 or 01), maybe do that tommorrow.
Beer
Old Sep 11, 2006 | 06:22 AM
charlie c5's Avatar
Hook the TPS wire to the "Blue" wire coming off the throttle position sensor pigtail on the throttle body. Hook the tack wire to the ground wire on one of your coil packs. Call Dave if you have anything else. His customer service is really freat.
Old Sep 11, 2006 | 07:46 AM
Beer. thanks. you always seem to be the one that digs me outta stupid problems. Your pics inthe wiring thread were perfect. Ill wire that up tonight and get everything else finished. Question. Where would I get 1 female-female fitting for the fuel rail? Like yours is on the fuel side.
Old Sep 11, 2006 | 08:12 AM
Beer99C5's Avatar
Its called a -4 swivel I got mine from Summit (I think), its a -4 female to a -4 female.
Sending you a PM with a link
I will update the programing on the wiring thread this morning.
Beer
Old Sep 11, 2006 | 08:30 AM
Beer99C5's Avatar
I would set it for 00, once you set it fire it up and press (and hold) button one as pictured it should show the correct idle speed (have someone rev it to watch it rise/falland check it vs the tach).
Pictured below is the little r and 07 for 700 RPM, if it does not match try a different setting and recheck.
Old Sep 11, 2006 | 09:44 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Connecting to the coil will be set at 00 for the tach input set up.
Ricky
Old Sep 11, 2006 | 12:40 PM
Beer99C5's Avatar
Its a great switch Ricky!
I bet there is a market for a single stage version too.
I will update the 00 in the wiring thread pics.
Pics and info here
https://ls1tech.com/forums/showthrea...77#post5276877
Post # 37
Beer
