Why do people hate ZEX
Bad
1. Zex bottle heaters suck, I bought a a/c only bottle heater and used a ac/dc convertor to power it. Heated to 1100psi in about 20-25mins from 650psi.
2. Purple is kinda gnarly looking.
3. The "Box" is a little bulky and hard to hide
4. Marketed as 'safer' than other systems, but it's not.
Good
1. Electronic WOT switch is MUCH better than a TPS switch
2. Easy to hook up, only 3 wires, idiotproof
3. Uses NX style pills, which are generally cheaper so you can customize your own shot for almost nothing.
Also, it will jet to 185hp. I talked to a knowledgeable rep, that actually tested the systems, and he said the solenoids are good for 185hp, in fact he sent me the exact jet sizes he used for a 185 hit if I ever wanted to spray it. The highest I went was 150 though, so I can't verify it personally, although I imagine he wouldn't lie to me and send them to me for no charge to try.
