Weird Idle after 125 Shot
Old Sep 17, 2006 | 06:50 PM
DragracrSS00's Avatar
Default Weird Idle after 125 Shot
Hey guys i'm new to the forum and i need a little expert advice. I just installed a NOS wet kit with a 125 shot. I tested it out last week and after i hit it and let off, my car idled like crap for about 5 seconds. Any ideas??
Old Sep 17, 2006 | 07:38 PM
SPRAYED 01's Avatar
That means its working properly. On a wet kit there is always some left over fuel after the shot that boggs the engine down for a few seconds. Dont worry about it. If it stops doing that you might have a problem of no fuel.
Old Sep 17, 2006 | 07:46 PM
so if it randomly jumps between 500 and 1500 thats normal??
Old Sep 17, 2006 | 08:30 PM
JoeyGC5's Avatar
As long as the car comes right back to a steady idle. What plugs are you using? Can you verify the air/fuel?
Old Sep 18, 2006 | 09:48 AM
Well it doesn't come right back, it takes about 4-5 seconds. Whatever came stock on a 2000 z28 are the plugs, and i have no way of checking on the a/f for awhile.
Old Sep 18, 2006 | 09:58 AM
white2001s10's Avatar
wet systems will do that.
Old Sep 18, 2006 | 10:54 AM
99Ws6TransAm's Avatar
You should definitly change your plugs. TR6's What rpms did you spray at? I ran a 125 from about 2800 to 5800 rpms..and my car never idled funny after. NX wet kit.
Old Sep 18, 2006 | 12:07 PM
I always hit it right when i shift into third, all the way up to the redline.
Old Sep 18, 2006 | 12:10 PM
Ls1Bait's Avatar
Yea change them plugs before you see a bigger problem than idle
Old Sep 18, 2006 | 01:46 PM
Blk97WS6's Avatar
with a 125 shot and stock plugs. your LUCKY a weird idle is all have wrong. but my wet kit will also idle funny for a second or two after spraying. nothing to worry about.
Old Sep 19, 2006 | 07:47 AM
NitrousDirect's Avatar
It's most likely your plugs, then if it went back to a normal idle they cleaned up. I would throw some tr6's on though
Old Sep 19, 2006 | 11:00 AM
00turboT/A's Avatar
It definetly sounds like you plugs.
