MSD window switch pills
Old Sep 21, 2006 | 11:13 AM
chris2000ss's Avatar
Default MSD window switch pills
guys,what on and off pills are you using ? I have mine set at 3000 on and 6000 off.my question is my rev limiter is set at 6800 rpm,should I bump up the off pill a little higher ??
Old Sep 21, 2006 | 11:20 AM
dirt track racer 81's Avatar
have it at 200 rpm below of whatever rpm you shift at
Old Sep 21, 2006 | 11:23 AM
the reason I ask is because it hits 6000 on the juice almost instantly LOL I think I may bump it up to 6200.
Old Sep 21, 2006 | 12:08 PM
Wile_E's Avatar
I have mine on at 3000 and off at 6400 with my limiter set at 6600. My shift light is set at 6300 so by the time I react to shift, it hits the cutoff rpm. Plus, I lift off the gas pedal between shifts so my WOT switch cuts if off anyway.
Old Sep 21, 2006 | 07:28 PM
skatinjay27's Avatar
what about for autos
Old Sep 22, 2006 | 03:03 PM
BADSZ28's Avatar
I think most keep them at 6000 due to the stock bottom end not handling the power after that. Some go a little higher but most do not risk it. I was wonderring this myself and found the above to be true and safest. I may go higher down the road, but will play it safe for the first few hits.
Old Sep 22, 2006 | 03:58 PM
formula87350's Avatar
How much are you spraying? I would probably set it at 6400-6500 if your limiter is at 6800.
Old Sep 22, 2006 | 07:16 PM
just a 100 shot for now..
Old Sep 23, 2006 | 01:10 PM
usd2sing's Avatar
here's a pertinent question.
what happens when u dont use the off pill/chip?
does it continue to spray until you let off the wot switch.
Old Sep 23, 2006 | 01:23 PM
yes it does but then your gonna be spraying through shifts,which some people do not feel safe doing.
