175 shot
Old Oct 13, 2006 | 03:00 PM
fstls1camaro's Avatar
Default 175 shot
is a 175 shot tuned safe to use on a full bolt cam camaro ss.
Old Oct 13, 2006 | 03:16 PM
sprydncamd ta's Avatar
in my opinion yes i have heads and cam and spray a 200/250 shot if you have the right safty stuff you should be in good shape with a tune
Old Oct 13, 2006 | 05:29 PM
02NBMWS6's Avatar
you spray a 250 shot on a stock bottom end?
i always hear that 200 is on the edge for stock bottom ends..
Old Oct 13, 2006 | 05:41 PM
Jassick's Avatar
i hope to god you upgraded the injectors. if not, you will run into problems. i think the limit is about 500hp on stock injectors (not completely sure.)
Old Oct 13, 2006 | 06:17 PM
B18B1LS1's Avatar
Depends on what kind of kit he is using, a big dry kit needs injectors, wet kit doesn't.
Old Oct 13, 2006 | 06:29 PM
it is a nx wet kit.
Old Oct 13, 2006 | 06:34 PM
02NBMWS6's Avatar
my car makes 555/689 on a nx 150 shot, Racetronix pump, and stock injectors, not sure what the duty cycle is, but they are fine according to my tuner.
and im definitely going to be spraying 200 on it soon, 175 should be fine for you
Old Oct 13, 2006 | 07:45 PM
i have 42# injectors and the harris speed works stand alone my injectors were pretty much maxed im running the hsw brute force kit
