smooth bellow and tnt ring
Old Oct 17, 2006 | 08:57 PM
bottledls1's Avatar
Default smooth bellow and tnt ring
so what bellow are you using on your tnt kit?
Old Oct 17, 2006 | 09:31 PM
Slow00ls1T/a's Avatar
https://ls1tech.com/forums/nitrous-oxide/591366-what-bellow-you-using-your-power-ring.html
Old Oct 17, 2006 | 09:38 PM
sleeperstyle's Avatar
STOCK bellow is what i used. follow that link, good info.
Old Oct 17, 2006 | 09:53 PM
bottledls1's Avatar
thanks. i think im going to go with a slp bellow since i have a slp lid.
also. the ring has a o-ring on the inside of it so it can seal to the throttle body. on your kits does the o-ring but up to the throttle body or deos it go over it?
Old Oct 17, 2006 | 10:40 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Go to TNT's site; they have all the installation instructions there. I should be putting my kit on in the coming week
Old Oct 17, 2006 | 10:48 PM
bottledls1's Avatar
what is there site?
Old Oct 17, 2006 | 10:49 PM
Oso SS's Avatar
Yes, the rubber o-ring goes up to the t-body but does not slip over it. I was trying to get it over for like 3-4 hours and it wouldn't go Finally brought it to the shop I bought the kit from and he slid it on and said "Done!"
It seems to be a common question though with the kit.
I used the stock bellow as well.
Old Oct 17, 2006 | 11:10 PM
bottledls1's Avatar
so when i switch to a fast 90mm throttlebody. im going to have to get rid of the tnt ring correct?
Old Oct 17, 2006 | 11:11 PM
JoeyGC5's Avatar
I took a file to the lip on the throttle body, so the ring slips on/off with a little bit of resistance.
Old Oct 17, 2006 | 11:41 PM
Z28/2002's Avatar
I think that TNT sells a 90mm ring. You would have to call them to make sure because it isn't listed on their site
TNT's site
Old Oct 17, 2006 | 11:52 PM
05gto60's Avatar
TNT's site
yes, they do make sell a 90mm ring. you need to specify which one cause i have an LS2 and got sent a 90mm LS1 kit. the power ring is a little smaller for the 90mm ls1s than the 90mm ls2s, and also has holes in a different location for the LS2 (they both have them at the 3-9 mark, but the LS2s other hole is at 1 compaired to the ls1s 2 o'clock position). that was also found out when i had the wrong power ring
