new trickflow heads dry 75 shot 582 rwp
Old Oct 23, 2006 | 10:05 PM
rmitchell242's Avatar
Default new trickflow heads dry 75 shot 582 rwp
this is stage 1
i hope to tune the 2nd next week
both stages dry tuned with hptuner
581/507 -75 shot
507-442 n/a
you can see more about the set up here
https://ls1tech.com/forums/dynamometer-results-comparisons/597079-507-442-stock-bottom-ls2-c6.html
and
https://ls1tech.com/forums/generation-iv-internal-engine/578719-tea-trick-flow-225-heads-came-today.html
Old Oct 24, 2006 | 06:55 AM
Patrick G's Avatar
LS1 Tech Administrator
Nice power on motor and spray. What size jets?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Oct 24, 2006 | 09:12 AM
algws6's Avatar
nice. what have you done to your fuel system?
Old Oct 24, 2006 | 10:43 AM
BigRon77's Avatar
Sweet! Those are awesome n/a numbers on stock cubes! What does your A/F hit when the spray comes on...looks like 16:1?
I'm hitting mine hard (1150 bottle pressure) on a 75bhp shot (shoots to 18:1 not even spraying the MAF directly and 14" away (in the filter of my LPE intake). I was 450/406 n/a on a very safe nitrous tune and went 529/500 on the 75bhp shot all through a 3200 stall auto.
Can't wait to see the 2nd stage!
Old Oct 24, 2006 | 05:11 PM
algws6's Avatar
what did you do to your fuel system?
Old Oct 24, 2006 | 05:54 PM
BigRon77's Avatar
I put in purple SVOs (47lbs) so they would be good with the 403 next year. Fuel pump on these cars are fine up to a respectable #...they put out some serious psi. If I go with 200 DP on the 403, then I'll put in higher volume pump.
My spike in A/F is at 3500 activation for about 1/4 second then a nice 11.5-6 all the way out to 6000 cutoff. No detonation.
Old Oct 24, 2006 | 07:38 PM
my af does not jump when the spray hits where you see the af high is at 2800rpm before i went wot. you can see at 4k when i spray it is right there around 12.4 the whole way up
Old Oct 24, 2006 | 11:38 PM
GTOtoGO's Avatar
Without ear muffs, sounded like the world coming to an end. Awesome power. With the nitrous, unbelievable. Congrats Robert.
Old Oct 25, 2006 | 12:04 AM
BigRon77's Avatar
Cool. It's hard for me to tell what mine is doing as the nitrous comes in at 3500 right as going WOT for the dyno run! I'm a little richer than you on mine 11.6 or so, but I had a little detonation around 5400 rpm with only 20* timing. Hoping that running a little Torco will settle it down.
What's your 2nd stage going to be?
Old Oct 25, 2006 | 11:30 PM
sditch's Avatar
Nice Numbers with the dry spray and NA, I got your same heads and having a 402 Blueprinted and built now. How do you like that cam, I went with a 224/228 on a 115 LSA for the 402 to try and keep the low end and driveability up but I feel like I should go bigger with the cam to let those heads work.
-Sean
Old Oct 26, 2006 | 02:44 AM
-Sean
yeah especially in a 402 my low end driveability is not that bad actually i think that my cam in a 402 would be pretty manageable and should make nice power!
Old Oct 26, 2006 | 02:48 AM
2nd stage will be another dry shot 75 i am thinking i may also reduce the first to a 50 we will see.
I hope to have my 60lb injectors friday i hit 110% duty on a 100 shot on the dyno just messin around it did not go lean though but to do 2 stages at a total of 150 i will need the 60's
