TEA trick flow 225 heads came today....
Look pretty sweet except for the mashed corner that ups put in one of the heads.
they are 58cc-12:1 cr, 225's and are going to swap out my lingenfelter stageIII heads that i am currently running they made 493 rwp N/A. I should have some dyno numbers for the Trick Flows with no changes other than the heads (and obviously some tuning adjustments) by the end of next week!!!
Thanks ups....
Thanks ups....
Can you say "Blown Headgasket" That sucks, I wish tose stupid neanderthals would be a little more careful with people's stuff. It's not so muchg the drivers as it is the guys who load the trucks. My buddy had a job loading trucks, and he and his friends would normally show up to work drunk since they went it for 3A.M shifts. Anyhow, looks like TEA did a great job as usual. Hope they flow better than the old heads. If you don't mind telling, how much did you pay for them?
Race your car!
as long as the tip of that corner is filed flat, the head should still be fine, it's on teh outer most edge, I don't think that ti would cause a problem as long as it's hit with a file before you try to install them.... leaving it will definately be a problem.
Ups's loaders are a good part of teh problem, but I think stuff like this is commonly underpacked too, I don't know how they were packaged, but if they were in a dense foam mold inside a box, this probably wouldn't have happened.... the blame is really on both sides. Packaging like I am talking abotu is expensive, but worth while, we have them made for our stuff @ my work and we never have a problem with damage, unless they drive over it with a truck, which has happpened too, but in that case anything is gonna get broke.
The ding on the corner is nothing to worry about. Just file it flat going away from the deck so you don't scratch the deck. Don't forget the corners usually just hang in the air anyways, about .040-.050" depepnding on your head gasket thickness.
What did they end up flowing! Thanks
Dave
Dave
My ETPs showed up with 3 bent corners! One was .045" over the deck! I filed them flat in the manner Sled described. I wanted to send them back because $2500 heads should look like a piece of jewelery IMO but they are hard to come by and I want to get the thing back together. Let us know what the new numbers are!
Dave
Dave
.1000 68.2 / 54.4
.2000 142.5 / 121.7
.3000 222.5 / 191.7
.4000 278.2 / 240.7
.5000 316.4 / 262.4
.5500 332.8 / 269.6
.6000 341.5 / 273.3
Collections Hold
flow
Originally Posted by rmitchell242
numbers for my heads flowed on 9/12/2006
.1000 68.2 / 54.4
.2000 142.5 / 121.7
.3000 222.5 / 191.7
.4000 278.2 / 240.7
.5000 316.4 / 262.4
.5500 332.8 / 269.6
.6000 341.5 / 273.3
.1000 68.2 / 54.4
.2000 142.5 / 121.7
.3000 222.5 / 191.7
.4000 278.2 / 240.7
.5000 316.4 / 262.4
.5500 332.8 / 269.6
.6000 341.5 / 273.3
Originally Posted by cary et performance
Is that an independant test or the data shipped with your heads? The heads are pretty!
The TFS is more sensitive to bore placement...meaning if you flow them on a doweled 4.00" LS1 bore like they are designed for, they flow well, if you just sit em on top of a bench and guess at where the bore is supposed be and flow them they are not very happy.
Is this on a stock shortblock? What is the displacement?
What is your redline set at?
Those dyno numbers are thru full exhaust with cats?
Your numbers so far are incredible. Curious how these new heads do. They are flowing near LS7 head territory. Great exhaust numbers as mentioned. Only potential bottleneck is the FAST 90 intake.
Collections Hold
tfs
Originally Posted by Brian Tooley
We just flowed a set of the TFS 225's vs the ET 225's, the TFS were better at .200", .300", .400" and .600"....with the smaller 2.05 intake valve the TFS comes with, vs the 2.08 of the ET.
