? about Progressive Controllers
Many of them look abosolutely horrifying to install and even worse to program.
BTW, this is for a street car and a lil bit of strip time. I am not looking at something like the FJO Maximizer or anything.
Very easy to install and very simple to use!
Dean
Its says "Black wire is the trigger wire (ground this wire to start the controller pulsing)." Does that mean I should hook it up to my window switch ground or my WOT switch ground or something else?
I think if I can get the activation figured out, I'm sold on it and will buy it.
http://www.harrisspeedworks.com/shop...cat=338&page=1
Seems easy enough to install and set up.
Or do you want something with a RPM and time based ramp.
Do you want it to have extra features such as window switch or TPS activation?
dave
Dean
NOS 5175 converted to wet kit
NOS window switch
WOT microswitch
I just want a simple kit that will work with my current setup without having to add solenoids or have a laptop to set it. And yes, I am just looking for a simple time based progressive controller.
