The importance of heating a bottle properly
Old Oct 25, 2006 | 05:18 PM
WS6HUMMER's Avatar
Default The importance of heating a bottle properly
I learned a little about this over the weekend. I would heat up the bottle with my CFN heater to 1100 psi and when I'd crack the bottle valve I'd loose 100 psi through the line. Well at the end of the track on my first nitrous pass ever my bottle pressure would read 800psi. The second time I took a little more time heating it up and got it up to 1200 and let it sit for a while and drop a little to 1150, well at the end of that run it read 900 psi.
That night I asked a friend there with me that was running a 3 stage 350 shot on his car (credibility) about what was happening and he told me that my bottle if heated real quick would loose pressure fast down the track. If it was heated properly (not too fast) it would only drop about 25 psi.
I think I might join the blow torch crowd and use one of those to heat my bottle from now on. I have to run my car to keep the battery good and hot while running my electric bottle heater. Anyone got any words of wisdom?
Old Oct 25, 2006 | 05:47 PM
srsnow's Avatar
Do not use a blow torch that can weaken the bottle and lead to a failure. Over 350 degrees the bottle needs to be condemned per 49 CFR 180.205 (i) (viii). The pressure drop isn't caused by heating the bottle too fast it is caused by starting with a higher pressure. The higher the starting pressure the faster the pressure will drop.
Old Oct 25, 2006 | 06:05 PM
WS6HUMMER's Avatar
Thanks, what you are saying makes a lot of sense. I def will rethink my blow torch idea.
Old Oct 25, 2006 | 09:14 PM
Robert56's Avatar
I allways open my bottles before I turn on the heaters, then no pressure lose from main line filling.
Robert
Old Oct 25, 2006 | 10:05 PM
Frans96SS's Avatar
a hot water tank is the best way...
Old Oct 25, 2006 | 11:30 PM
mrdragster1970's Avatar
6 & 8 Second Club
We use a 120V heater, than you can just plug into generator. I have a battery and inverter in the golf cart for long delays. I just saw a dual system (110V & 12V) this week, haven't looked into it yet, but that might be something I buy next if it works with 16V. The air or water heater box's are cool also, I don't have one, but friends do, and they love them.
Old Oct 26, 2006 | 07:35 AM
BIG_MIKE2005's Avatar
I agree on the heated boxes being good to invest in if you spend time at the track.
There are a few people around here with them. I know theirs can fit 2 bottles in the box & they can either be 10 or 15lbs in size. They seem to be very effictive at keeping the bottles nice & warm while waiting between races.
Then while in stageing lanes you could just use the regular bottle heater in the car to maintain the pressure w/o it having to be on constantly.
Old Oct 26, 2006 | 07:48 AM
WS6HUMMER's Avatar
Robert
Is'nt that dangerous for your nitrous line? Wouldnt the heat from the engine raise the pressure in that part of the line and risk blowing the line? I have to run my car to keep the battery up, remember,
Old Oct 26, 2006 | 07:58 AM
WS6HUMMER's Avatar
My friend that runs the 3 stage 350 shot has one of those, it heats 2 bottles. He offered to put my bottle in there erlier in the day and I let him but I didnt start spraying until after dark (9:40) and he was racing in a true street class and needed it to heat his own bottles by the time I needed it. He won his class that night though.
Old Oct 26, 2006 | 08:00 AM
WS6HUMMER's Avatar
I've used a big aluminum pot on my stove with water when testing my stuff close to my house. This made the nitrous hit harder on my car than I ever have experienced. Might bring my propane fish cooker and my Crawfish boiling pot to the track next time!
Old Oct 27, 2006 | 02:55 PM
Reject's Avatar
some tracks will kick your *** out of there if they catch you doing the blow torch jig. just a FYI
Old Oct 27, 2006 | 04:34 PM
WS6HUMMER's Avatar
Heard about those tech guys.
Old Oct 27, 2006 | 05:04 PM
Todd157k's Avatar
News Headlines:
Small Thermal Nucular Device takes out Neighborhood in Alexandria, LA.
And makes Tasty Dinner
Old Oct 27, 2006 | 07:23 PM
mrr23's Avatar
ummm, no. i use my rear defroster on mine. yes, the key needs to be on, but car isn't running. defroster has a nice 15 minute built in timer. i have my bottles open 24/7, personally. had bottles in excess of 1500 psi due to florida heat. drive around with them open. never broke a line, yet.
Old Oct 28, 2006 | 09:39 PM
red91z's Avatar
LS1TECH Sponsor
The key is to get the bottle warm throughout. Take you a bottle and heat it up a bit. Then turn it upside down a few times an the pressure will drop. The heat takes a while to transfer throughout the contents.
Old Oct 29, 2006 | 08:51 AM
Johnny5's Avatar
The way I have my heater rigged to a pressure switch it won't heat anything until you open the valve. It seems to work OK.
Old Oct 29, 2006 | 10:17 AM
sleeperstyle's Avatar
get a bottle blanket, or be cheap like me and wrap a jacket around the bottle/heater. 1/2 hour and i see 1000 psi (unless it is really cold out) and it stays up pretty good during a run. doesn't drop below 900. you gotta keep it insulated, and the blanket/ jacket (haha) keeps the heat in so the ambient air doesn't affect it.
Old Oct 29, 2006 | 03:06 PM
terry s's Avatar
Any pressure increase from engine heat on the nitrous line will be minimal as long as the bottle valve is open because the puessure will equalize back to the bottle.
Old Oct 29, 2006 | 04:00 PM
Robert56's Avatar
Actually the engine heat can cause the nitrous to turn to vapor. That's what happens when it get's to hot. One of the reasons for a purge. At 95* a bottle will be about 1050/1100psi, if you check the heat in the engine bay you'll see it's a much higher temp, and only causes a local problem concerning the line. I have mine wrapped to help with the heat issue.
Robert
Old Oct 29, 2006 | 04:47 PM
terry s's Avatar
Robert
Robert is right. I was referring to pressure not the vapor issue. I have my entire line from the bottle to the solenoid covered with fuel hose to keep it from being chafed anywhere and to insulate it from engine heat.
