Cutout Switch to Opener Switch?
Old Oct 25, 2006 | 11:57 PM
99_Z_155's Avatar
Default Cutout Switch to Opener Switch?
Ok, i have the qtp cutout switch. i got the switch panel for my nitrous from dave, and i am trying to make the switch for the bottle opener work for my cutout. the new switch has 6 pins, and the old one has 8, all used. how do i wire this up?
Old Oct 26, 2006 | 06:39 PM
99_Z_155's Avatar
Nobody?
Old Oct 31, 2006 | 02:44 AM
frknlo's Avatar
I believe the qtp switch is also lighted so thats why there is 8 pins. Two of the extra ones should of gone to a separate ground to complete the circuit for the light in the switch.
Old Oct 31, 2006 | 07:18 PM
99_Z_155's Avatar
thanks man, but i dont entirely understand that schematic...i need to know which attachments on the switch go to the opener switch. some are connected to each other and whatever. its confusing.
Old Nov 1, 2006 | 01:58 AM
frknlo's Avatar
Note: little black dots are connection points, if there is no black dot and wires intersect then there is NO connection there.
First off there should only be 2 wires coming from the cutout. In the image above its the largest black wires coming from the cutout with connection points A & B.
Lets start wiring:
•12volt supply will go to the pin #2
•Ground will go to pin #5
•Pin #1 and #6 will be connected together to cutout wire A
•Pin #3 and #4 will be connected together to cutout wire B
•Thats the end of it!
Is it understandable now?
Old Nov 1, 2006 | 08:12 AM
99_Z_155's Avatar
yeah. i understand that now. its just i dont know what cutout wires A and B are that are currently on the stock qtp switch.
Old Nov 1, 2006 | 07:44 PM
frknlo's Avatar
I dont know how else to explain it but there should only be 2 wires coming from the Cutout(not the switch but the actual cutout unit itself). In the grey wire harness there should only be 2 wires coming out of it. Find these two and you ll find the A/B.
If you could post pics of the wiring harness I may be able to help more.
Old Nov 1, 2006 | 07:45 PM
99_Z_155's Avatar
no need to. i think i know what you are saying. what should i do with the rest of the connections? just tape them off?
Old Nov 1, 2006 | 07:53 PM
frknlo's Avatar
How many connections will you have left? two? It should be the ground wires for the light of the old switch, then yes tape it up.
btw do you have a multimeter??
Old Nov 1, 2006 | 07:58 PM
99_Z_155's Avatar
ok, i will just tape em off. and no, i dont have one surprisingly, after all the wiring crap ive done.
Old Nov 1, 2006 | 08:17 PM
frknlo's Avatar
LMK how it goes!
Old Nov 1, 2006 | 10:51 PM
B.W.'s Avatar
Lets start wiring:
I tried this after many other configurations and FINALLY I can get my switch to work. Thank you so much!
I have a DMH cutout and had to make a daisy chain type harness to make the two wires from the cutout motor into four.
