Is a nitrous filter recomened?
Old Nov 19, 2006 | 06:45 PM
Robert56's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
I always put my filters at the bottle. This way if there is trash in the bottle it does not go into the main hose. You can get solenoid fittings with a screen in them incase something comes from the hose. The chances of the inner liner of the teflon hose comming loose is very slim..
Dave
Yes that'll work, and have done this. However, if using just a single filter I think the noid location will get the job done better than at bottle. We set-up a flushing of all out hydraulics at work prior to a finished product, you would be amazed at all the shavings that show up from over tightened AN fittings. This is even worse with aluminum fittings used in the n2o world, a small piece of the fitting surface can come off at anytime, espec when putting hose off and on from time to time. Having the filter at the bottle will not collect this debri if you have a single filter. Those fitting filters kinda suck IMO, and can be a source of phase change.
Robert
