gear lockout wiring diagram need
Old Oct 28, 2006 | 07:47 PM
CHIWS6's Avatar
Default gear lockout wiring diagram need
i wired the blue wire to the wot switch and the orange to a ground but it doesn't work, any help would be apreciated. thanx
BTW this is the switch i have http://www.dynotunenitrous.com/store...?idproduct=194
Old Oct 28, 2006 | 09:03 PM
BuBbABFP's Avatar
I think its be better if you use your TPS wire(but i am not sure if it uses the tach lock the gear or tps), i think orange is for a 2nd stage.. (i didnt use the orange) anyway I tried to wire the blue one to the supplied TNT micro switch but we couldnt get my noids to work, so we wired it to the TPS wire and everything worked smoothly. anyways i havent really tried the gear lock out, but i think it works best from a dig, you arm it and while while ur rpms clime and you shift into second it sees a fall on rpms then it knows you have gotten out of 1st and it will now shoot as soon as it goes into second. Btw i am gonna try it tonight.
Old Oct 28, 2006 | 09:31 PM
CHIWS6's Avatar
so the only wire that u connected was the blue wire but what other 1 do i have to connect it in order to activatethe gear lockout? which wire did u splice into the the TPS sensor?
Old Oct 28, 2006 | 09:39 PM
Beer99C5's Avatar
Are you selecting the gear lockout during programing?
The Gear lockout reads the tach sweep.
Does the window switch work? If it does than the gear lockout should too, you just have to program it.
Here is a link to the instructions.
Trick Window Switch Instructions
Old Oct 28, 2006 | 09:55 PM
CHIWS6's Avatar
once again, thanx for helping me out beer99c5
i think i figure it out but correct me if i'm wrong fellas,
blue wire is not connected at all and STEP 7 is turned OFF (03) but my ground wire that i need for my WOT switch goes connected to the yellow wire of the SWITCH. is that right?
Old Oct 29, 2006 | 10:24 AM
CHIWS6's Avatar
ttt
Old Oct 29, 2006 | 05:54 PM
CHIWS6's Avatar
how exactly do i wire the switch if i want use the tps sensor as the signal?
Old Oct 29, 2006 | 05:57 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
The blue wire is for your TPS function. The yellow wire should go to your relay as its the trigger wire for the first stage. Best bet is to give us a ring or emial us your phone number and we will be glad to call you and walk you through it!
Dean
Old Oct 29, 2006 | 06:51 PM
algws6's Avatar
so basically if i have the WS set from 3000 to 6800 and i am shifting at 6700 i cannot use the gear lock out feature?
Old Oct 30, 2006 | 09:33 PM
CHIWS6's Avatar
TTT for the night
