Cold Fusion Nitrous Controllers Are In!!!
Old Oct 30, 2006 | 08:57 AM
NitrousDirect's Avatar
Lightbulb Cold Fusion Nitrous Controllers Are In!!!
These all new controllers are finally in after much beta testing and tweaking to make them just perfect CFN has finally released them!!
These bad boys can control up to 4 solenoids
This unit was designed to allow the aggressive use of nitrous power and putting it on the ground. A simplified wiring harness and easy to adjust push button LED controls makes this device a breeze to install and use.
The start percentage can be adjusted from 1% to 100% in 1% increments.
The Nitrous build time can be adjusted from 0.0tenths (instant 100%) to 8.0 seconds in 0.1 tenths of a second increments.
It also has 2 modes for automatic cut off or continue the count down. It is activated by your WOT switch or your push button switch that activates your nitrous kit.
The high amperage drivers can handle all of today's high amperage solenoids.
Infact, this controller is so heavy duty it can control 4 large PRO solenoids used on a V8 FOGGER KIT!!!
Overall dimensions are 4x3x1.75.
This device is perfect for your nitrous installation and is a must have if you are running shots over 50HP for your engine's safety and longevity. The "hit" of nitrous is what damages components and what has given Nitrous a bad name, but with this heavy duty digital controller you won't have to worry about any of that.
You can find them here:
Nitrous Controller
This is definately a great unit guys and to kick it off we'll offer free shipping on them starting now untill the end of November!
Old Oct 30, 2006 | 11:21 AM
ALBERT@COLD FUSION's Avatar
Nice looking controller. Works great!!!
Old Oct 30, 2006 | 02:29 PM
Justg's Avatar
Can this be used with a window switch? If so does it start the progressive pattern over with every shift?
Old Oct 30, 2006 | 03:34 PM
WS6ZILLA's Avatar
so what are these 2 modes? My best guess is if you lift it can either start over or keep going when you get back in it, is that right?
Old Oct 30, 2006 | 04:11 PM
it can start over in mode 1 or it can start off where it left off at in mode
and yes, it can be wired up with a window switch.
and yes ws6 you are correct!
Old Nov 1, 2006 | 08:02 AM
to the top
Old Nov 1, 2006 | 08:50 AM
Bandit2150's Avatar
can in be used with the LS1 timing tuner??? I am using the timing tuner to pull timing as well as a window switch.....will this pose a problem?
Old Nov 1, 2006 | 10:03 AM
Somebody09's Avatar
So it's strictly time based?
Old Nov 1, 2006 | 11:36 AM
starting 0-100% power over time you set
