Iron 408 Nitrous Limits
Old Nov 3, 2006 | 10:05 AM
bottlebabyWS6's Avatar
Default Iron 408 Nitrous Limits
Right now I have a LME Iron 408 with the usual forged internals (eagle crank, callies compstar rods, wiesco custom nitrous pistons). I just installed a direct port set up with a progressive controller and just wondering how much this bottom end should hold with the proper tune. Any suggestions would be aprreciated.
Old Nov 3, 2006 | 11:23 AM
TOS98SS's Avatar
A ton I don't think it gets any better then that
Old Nov 3, 2006 | 05:35 PM
ls1408cp's Avatar
I have the same lme motor and he said 300 would be easy
Old Nov 3, 2006 | 08:08 PM
next's Avatar
I'm sure LME built a great motor but you really should be asking them. In almost all cases a well built bottom end on these motors is not the issue, the clamping force of the heads are.
Old Nov 3, 2006 | 08:44 PM
pewter 01 SS's Avatar
what advice do you give inorder to keep the heads well in place?
Old Nov 3, 2006 | 09:01 PM
next's Avatar
Back to the first post question - I'd agree that a 300 hit is a good target number for most well built nitrous LSx motors.
Pewter - If you asking about up to a 300 shot, a set of ARPs will ususally work fine.
Old Nov 4, 2006 | 12:52 AM
SSilverSSurfer's Avatar
did you get the hellfire rings also?
Old Nov 4, 2006 | 11:29 AM
It has the hell fire rings and it was built for nitrous. I have asked bryan and he said 300 should be fine I just want a second opinion because I am getting ready to spray a 300 shot and need to settle my nerves a little before I let it eat.
Old Nov 4, 2006 | 11:33 AM
1999TransamWs6's Avatar
300 will be easy on that motor, I was very close to a 300 on my 346 with a stock bottom end, all I had was some head studs and rod bolts.
Old Nov 5, 2006 | 03:03 PM
GueSS Who's Avatar
I have an iron 412. I should be on the dyno in the next couple of weeks. 300 on each stage. 2 stages on a motor that already makes 600 to the tires. Should go pretty fast if it holds. Dart heads with 1/2 in head studs and cometic gaskets. Shooting for 1K+rwhp
Old Nov 6, 2006 | 10:22 AM
tttttt
Old Nov 6, 2006 | 11:16 AM
blackls6's Avatar
I am not trying to hijack the thread or anything but: What would it take to be able to safely spray a 300+shot on an iron 408?
Old Nov 6, 2006 | 02:59 PM
PIMP_2's Avatar
I watch buddy's car spray 350+ on 402 Aluminum block at least twice a week. Eagle crank, callies H beam's, diamond pistons with dropped ring landing. Car made 844rwhp and it is also a DD. He is spraying the Direct port NX kit. Using the 350 pills he picked up 341rwhp
