N2O and Fuddle Stalls
Just curious what types of results others are having with a N20 kit and a Fuddle stall. I have a HSW Sudden Impact single nozzle dry kit (75-125HP) and a Fuddle 3400 2.1 stall. I am going to use the 100 HP jet. I am also going to use a RPM window switch to eliminate spraying through shifts and I will most likely also not spray in 1st. I am hoping this setup will put me into the high 11's. THANKS.
I had a NOS Plate kit wiith a 150shot and a fuddle 3,600 2.2str and it was horrible it just blew right through the converter i picked up 5tenths and 6mph just by putting the stock converter in! But every car is different!
Originally Posted by ARCTICWHITE98Z28
Hmmm - that is strange. I went from 13.8 before the converter to 12.9 after the converter and DRs. I am hoping the N2O helps even more.
formerly silverbrick (changed 02/17/2013)
When you say "crapped out" do you mean the converter broke in some way? Thanks.
Seemd to have blown right through and then the trans gave out.....opened up the trans and everything was perfect except the converter. John was really cool about it though....its still under warranty so I'm going to send it back to get fixed...
