Fuel Pressure Drop While Spraying?
During normal operation (on motor) the car averages anywhere from 58-61psi (per my Dynotune gauge). While spraying, the fuel pressure will drop to low 50s/high 40s on the gauge. Is this normal? An injector/rail upgrade is in the planbook for over the winter, but I want to run a few bottles through it before I put it away for the season.
The lowest I've seen the fuel pressure go is 48, it mostly stays around 50 even until we stop spraying.
What do you think - spray and be happy, or use caution? Thanks guys.
I use the jet chart for 48-55 psi instead of 55-60 but it was still lean. Had to go even bigger to compensate for the lack of pressure to the injectors too.
I can't use the second stage because of fuel pressure so this winter a dedicated cell
Robert
Matt
Nitrous Direct Stand alone
Robert
