plate vs. nozzle
Old Nov 7, 2006 | 12:01 PM
2002_B4C's Avatar
Default plate vs. nozzle
I have been running a nozzle kit. Wondering if anyone has any experience with a plate kit, and if it is better or worse than a nozzle? Thanks in advance.
Old Nov 7, 2006 | 12:07 PM
BadAssFast's Avatar
Which one...my Nitrous Outlet 90 mm plate w/ 200 shot controlled by an FJO mini hits like Mike Tyson on steroids mad at the world...thank god for 1st lock out.
Old Nov 7, 2006 | 12:23 PM
TchargedLS1TA's Avatar
I think the plate would be better because you are getting better N20/fuel atomization and more spray area than a nozzle..
Old Nov 8, 2006 | 01:56 AM
gmpower's Avatar
Is the nitro dave plate better than the NX maf?
Old Nov 8, 2006 | 11:57 AM
siniSSter's Avatar
I have the NOS Plate, works great hits hard outta the hole....go plate you won't regret it..
Old Nov 8, 2006 | 02:43 PM
ShiznityZ28's Avatar
I run a pro flow plate on my vic jr. made 235 on a 225 shot
Old Nov 10, 2006 | 06:55 PM
nastyta's Avatar
If it makes a difference im going with the nitro daves plate setup 200 shot, heard alot of great stuff about the kit...
Old Nov 10, 2006 | 07:25 PM
Robert56's Avatar
The plate kits are just an evolution of the nozzle style kit. A dual nozzle kit will produce the same power and distribution, however, the plate kits are much tricker and cleaner.
Robert
Old Nov 11, 2006 | 01:46 AM
1320 killer's Avatar
I am planning on using the tnt 90mm power ring in the next couple of weeks. before I do this what is better the power ring or a plat? sorry to leach off your thread. but you might want to think of the power ring also
Old Nov 11, 2006 | 10:06 AM
Robert56's Avatar
I would say it's still personal preference, as the power ring is also pretty trick.
Robert
Old Nov 12, 2006 | 06:05 PM
Default 90mm PLATE vs. NOZZLE
WELL, I have a few questions.
1) what are the benefits of using a plate over the nozzle?
2) Where can I get this plate at? Are they custom made or can I get them from a vendor?
I tried to use the search option but it seems to be down again. Thanks in advance to all that can help.
Old Nov 12, 2006 | 06:08 PM
TWS's Avatar
TWS
Call Dave Vasser, aka. Nitro Dave. Sponsor --->
Old Nov 12, 2006 | 08:28 PM
Robert56's Avatar
Look down a few threads, this exact question was just raised.
Robert
Old Nov 12, 2006 | 11:05 PM
Nitro Dave's Nitrous Outlet's Avatar
The benefit between most plates on the market and a nozzle are nothing more than the looks of the install.
However the Nitrous outlet plate may have some perks other than looks.
Our plate is desighned with 6 nitrous and 6 fuel discharges. Do to our desighn we are breaking up the mixture for the best attomization possible.
Now compared to a well desighned nozzle That is placed before the throttle body I dought you will see to big of a difference if any.
There is a tread on here tittled NOTHING COMPARES TO OUR PLATE.
It has some good info in there. Ill see if I can find it.
Dave
Old Nov 12, 2006 | 11:31 PM
thanks to all. I will see if I can find that thread.
Dave
Old Nov 12, 2006 | 11:47 PM
The search button is not working right now. However in this post Beer has a video of the discharge. Check it out.
https://ls1tech.com/forums/showthrea...20#post5869520
Old Nov 13, 2006 | 11:46 AM
Thanks again a lot of info.
Old Sep 22, 2007 | 05:22 PM
Dragman's Avatar
question has anyone done a back to back test at dragstrip??
