jetting with direct port
How to i know the correct jetting without getting 10 sets of jets x 8 for nitrous and x 8 for fuel?
Is there a Mr T starter jetting kit that you can pick up without being raped by the set?
I am running a independent fuel system up front for the fuel, how does this change the fuel jetting?
My plan is to start at 200 shot and work my way up as the car takes to it..
Before it was to easy, 1 fuel and 1 nitrous off the main fuel line.. Now im getting a little nervous and not alot of room for error.. HELP!!!!!!!!!!!!!!
Bradco TH350, GTP Stage 2 Heads, TR 244, FAST 90/90, QTP 1 7/8, Duals, NOS Direct Port, FIPK,Wolfe Cage, Strange 12 Bolt, BMR suspension, Qa1's, ET Convo's with MT Drag Radials....
"while your post count gets higher. my ET gets lower"
You've got $10,000 in motor.. You're going to need $200 in a jet kit. Different days, diff tracks, etc.
Bad azz set up dude.
yup,
I have for my 175 shot:
nos 24
fuel 24
I ordered 26 for the NOS side for a 200 shot.
should be just right casue the 24/24 runs rich
Unflortunately, there is no getting around having to buy all the jets.
Fuel pressure 9psi
150hp N24 F20
200hp N26 F20
300hp N31 F24
400hp N35 F26
500hp N41 F28
600hp N46 F31
I question the 150 shot as my car shows A/F below 10.0 when I sprayed it. I might have a clogged nozzle but the plugs look good. I even dropped the fuel pressure to 8.5 and the A/F is still low low. Any thoughts? I'm not going to run it until I figure this out.
