Boltons + Cam + Nitrous + Stock Bottom End?!
Old Nov 12, 2006 | 09:14 AM
ChrisUlrich's Avatar
Default Boltons + Cam + Nitrous + Stock Bottom End?!
How many guys are running decent sized cams and nitrous?
I'm talking like the TSP 233/239 Cam. Something that'll make about 400whp and 370wtq n/a or in that area along with a 100-150 Shot of nitrous.
All this done on a stock bottom end... i'm trying to find the breaking point on the LS1 stock bottom end. Right now the car has 58k on clock... figure 75k on clock when the Cam goes in... meanwhile the gap from 58k to 75k will have nitrous use. Nothing crazy since i'm kind of a bitch. haha
Old Nov 12, 2006 | 09:51 AM
GM Muscle's Avatar
If the set up is dialed in you should have plenty of room to play. 150 shot shouldn't be a problem at all. If done right you can probrably get away with a set up that peaks at about a 250hp shot and still have the bottom end last for awhile.
Seems that most people break the rod bolts in the 700-720hp range at the crank. Of course, there is alot that can go wrong even before you get to that point. Do your homework on tuning.
Old Nov 12, 2006 | 10:00 AM
Matt@HSW's Avatar
Quite a few spray on head/cam combos with the stock bottom end (and making well over 600 to the rear). How much you spray will somewhat determine the life of the motor, but if everything is set up correctly with no problems (fuel system, tune and so on) 550 to the rear wheels shouldn't be a problem.
Matt
Old Nov 12, 2006 | 01:29 PM
Robert56's Avatar
Like was said, go for, no problem if tuned correctly.
Robert
Old Nov 12, 2006 | 03:05 PM
Blown2000SS's Avatar
Do it.
Old Nov 12, 2006 | 05:08 PM
BigDB's Avatar
i have a F13 cam, made 385rwhp on a n2o tune, N/A tune made 416rwhp. On a 150 I make close to 550rwhp on a stock bottom end and take it to 7100RPMs with 103K on the clock
Old Nov 12, 2006 | 06:43 PM
bad6as's Avatar
Stock Lifters?
Old Nov 12, 2006 | 07:30 PM
BriancWS6's Avatar
446/411 on motor then the occasional 100 shot, which brings the torque into the 600+ range
Old Nov 12, 2006 | 08:54 PM
That's awesome! I have been seeing that people do it... but just wanted some peoples opinion direct.
Because I just LOVE n/a power because I was raised on that type of crap. But since i'm not a rich bastard... haha I need to budget my power. Nitrous seems like a good starting point, then the TSP cam or something a tad larger. I'm not sure yet... thanks everyone!
Old Nov 12, 2006 | 09:31 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Times in sig with a F13 and 150 shot
Old Nov 24, 2006 | 01:13 AM
BigDB's Avatar
Originally Posted by bad6as
Stock Lifters?
I beleive so. the cam was installed by the owner before me. Its got comp pushrods and a LS6 intake so maybe he pulled the intake and did lifters then. But its holdiong up great, just about to get the car back together and cant wait.
Old Nov 24, 2006 | 10:44 AM
GasTiresandOil's Avatar
HPE S-cam and a 150 shot. Plenty of bottles through without a problem.
Old Nov 24, 2006 | 11:18 AM
sprydncamd ta's Avatar
f-13 dart 205's and a 200/250 shot
n/a 444.4
spray 675
oh yea stock bottom end
Old Nov 24, 2006 | 03:53 PM
dlc1609's Avatar
lifters are actually under the heads on these motors so he'd of had to pull the heads too to get to them.
