Dynotune
Old Nov 12, 2006 | 12:01 PM
mattraypharbor's Avatar
Default Dynotune
YO im buyin a nitous kit from dyno tune but im new to n20 does this kit come with everything i need and also how does the micro switch work and where does it mount???
http://www.dynotunenitrous.com/store...?idproduct=118
thanks..
matt
Old Nov 12, 2006 | 12:09 PM
125 shot for eveyones info...
Old Nov 12, 2006 | 12:25 PM
Beer99C5's Avatar
Dean and Dan @ Dynotune are da bomb YO!
You will want a heater, window switch, bottle gauge (or remote gauge) and colder plugs to finish off da job.
PM them and they will send the instruction sets for what your gettin.
Old Nov 12, 2006 | 12:32 PM
Whats the difrence between the micro switch and the wot switch and the window switch and witch one works best...i wanted just to use the parts that are provided in the kit...??? sorry for my ignorence i have no clue about how n20 works..also do you guys think i will se 6's in the 1/8th with a 100-125 shot...right now im runin high mid 7.5s-7.6s?
Old Nov 12, 2006 | 12:33 PM
i always though that once you arm the bottle all you have to do is floor the car and it will inject the 100 shot with the micro switch??
Old Nov 12, 2006 | 05:38 PM
BTLFEDSS's Avatar
Definetly want a window switch so it spray in the right RPM's,stops it from spraying through shifts and keeps from sraying in the rev limiter
BTLFEDSS
Old Nov 14, 2006 | 10:57 PM
is it easy to set up? the window switch that is... to set it for not sprayin into the shifts and at the rev limiter?
Old Nov 15, 2006 | 06:45 PM
BTLFEDSS's Avatar
basicly you just set it a couple 100 rpm's before what your shift point is which would keep you from spraying through shifts and the revlimiter
Example:
3000rpm activation
6300rpm deactivation
6500rpm shiftpoint
6800rpm revlimiter
BTLFEDSS
Old Nov 16, 2006 | 10:33 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
Example:
3000rpm activation
6500rpm shiftpoint
6800rpm revlimiter
BTLFEDSS
Well said!
Let us know if we can help!
Dean
Old Nov 17, 2006 | 10:19 AM
Example:
3000rpm activation
6500rpm shiftpoint
6800rpm revlimiter
BTLFEDSS
gotcha thanks for the info
