nx switch panel problem maybe.
Old Nov 14, 2006 | 09:44 AM
Z284U2TRY's Avatar
Default nx switch panel problem maybe.
Ok just finishing up a new set up on my car and everything hooked to the panel is working correctly. When I turn on the heater the large light at the top of the switch lights up. when I arm the n20 system I get no light but it works. My best guess is that when the heater is on the lower light should be on and when the n20 is armed the large light should be on. Anyone have a picture of the back of there nx switch panel. I saw one a few weeks ago but can't find it again in the search. i have double checked all my connections.
Old Nov 14, 2006 | 09:47 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
On that switch there is a large light and a small. The small is pretty hard to see in the day time.
If you want the large light to be the system, just switch the heater controll and the system wires on that switch.
Now only one light should be on at a time if all is wired up, like instructions.
http://www.nitrousexpress.com/Instru...witchpanel.pdf
Ricky
Old Nov 14, 2006 | 09:56 AM
Z284U2TRY's Avatar
Ok I wired it up as per directions so the large light is suppose to be the heater and the small light is the arm light per default?
Old Nov 14, 2006 | 06:06 PM
Z284U2TRY's Avatar
What no one wants to guess? Well I took the switch apart piece of cake nothing to them. I feel as the bulb is shot and it can't be changed. everything works as should.
Old Jan 23, 2007 | 09:18 PM
MIGHTYMOUSE's Avatar
james, you find a place to get replacement parts? i need a momentary switch for one of mine now for the trans brake
Old Jan 24, 2007 | 02:52 PM
Z284U2TRY's Avatar
Yes I found replacement parts.
