FPSS Calibration
Old Dec 8, 2006 | 05:42 PM
99FRC's Avatar
Default FPSS Calibration
In calibrating my FPSS, I turned the set screw until it shut off at idle (approx. 58 psi). I then turned it back until it just clicked on. Is that the correct way to calibrate it? Any other methods?
Thanks!
99 FRC
Old Dec 8, 2006 | 05:46 PM
00formLs1's Avatar
i would also like to know
Old Dec 8, 2006 | 06:03 PM
jj_z28's Avatar
Same here.
Old Dec 9, 2006 | 02:06 AM
00formLs1's Avatar
anyone?
Old Dec 9, 2006 | 12:19 PM
Camaro94SS's Avatar
yeah i would like to know this as well....
Old Dec 9, 2006 | 12:32 PM
Jake@EPP's Avatar
The problem with turning it back to where it just clicks on is that when the juice hits you will probaly see a small drop in pressure which may de-activate the system, you have to calibrate for pressure loss.
Old Dec 9, 2006 | 01:50 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Remove the bottle from the car......Take the fuel line off the nozzle....have an assistent hold the fuel line into a catch can.....bring the vehicle up within the RPM window and activate the kit......slowly tighten the adjusting screw until the sytem starts to pulse/shut down, then back the screw off 3/4 of a turn.
Old Dec 10, 2006 | 01:48 AM
00formLs1's Avatar
thanks ray
