Bottle In Between Rear Seats ?
Old Dec 8, 2006 | 06:25 PM
wicked z28's Avatar
Default Bottle In Between Rear Seats ?
I Was Wondering If You Guys That Have The Bottle Mounted In Between The Rear Seats Are Passing Tech At Your Local Street Legal Dragstrip,what Are You Guys Doing With The Blowdown Tube If Your Passing It.i Want To Put Mine There But I Want To Pass Tech Inspections When I Go.
Old Dec 8, 2006 | 06:36 PM
iamsickofitall's Avatar
get the blowdown tube kit from nitro dave and run it out through the grommet under the rear passenger seat...or you can make one yourself
Old Dec 8, 2006 | 07:14 PM
Brian2006's Avatar
That's why the bottle sits in the trunk during tech
Old Dec 9, 2006 | 01:54 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
I just put an extra bend in my blow down tube for it to meet up with the tranny tunnell
Old Dec 9, 2006 | 01:55 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
that works also
Old Dec 9, 2006 | 02:05 PM
Hennytime's Avatar
i put a bag over mine and osw doesnt know the difference
Old Dec 9, 2006 | 03:48 PM
wicked z28's Avatar
I Have The Blowdown Tube What Do I Need To Make That Work Some Kind Of Hose Line How Do I Get It On The Blowdown Tube.
Old Dec 11, 2006 | 03:16 AM
KrautBurner's Avatar
I just got tygon tubing from Home Depot
Old Dec 11, 2006 | 11:21 AM
00formLs1's Avatar
dose anyone have a pic of it exiting under the rear seat?
Old Dec 11, 2006 | 02:26 PM
wicked z28's Avatar
Yeah,that Would Be Great,tygon Tubeing And How Did You Get It On The Blowdown Tube Any Pictures You Can Post.
Old Dec 11, 2006 | 03:43 PM
Nitro Dave's Nitrous Outlet's Avatar
This kit is perfect for what you are doing.
http://www.nitrousoutlet.com/catalog...roduct_id=1116
Old Dec 11, 2006 | 10:54 PM
00formLs1's Avatar
thanks dave.
Old Dec 12, 2006 | 11:23 AM
wicked z28's Avatar
Ill Keep That In Mind Thanks
Old Dec 12, 2006 | 07:07 PM
BBBBadSS's Avatar
I just double hose clamped a piece of hose to the end of the blowoff tube and ran it under the pass. side rear seat. You cant see the hose clamps because there along side the seat.
Old Dec 12, 2006 | 10:27 PM
98redorangeta's Avatar
8an line works and just run it out under the seat.
Old Dec 13, 2006 | 02:58 AM
ChaseSS's Avatar
yeah i would like a pic too please
Old Dec 13, 2006 | 10:56 AM
Correct.But.... In order to be safe it really needs to connect to a bulk head atached to the car. This way if the burst disk was to pop at 3000 psi the hose does not become a hazard whipping around through the air..
That is alot of pressure...
Dave
Old Dec 13, 2006 | 11:18 AM
nfa's Avatar
nfa
http://memimage.cardomain.net/member...10_59_full.jpg
Mounted behind passenger seat... there is a grommet perfectly lined up to allow the blowdown tube to pass through.
Old Dec 14, 2006 | 04:03 PM
Dave
My idea was to zip tie it to the sub frame connecters probably not the best idea ever but cheap.
Old Jan 5, 2007 | 09:48 PM
MOTRUBL's Avatar
I just drilled a hole. I can plug it if I ever want to take it out.
