broken spark plug, possible damage?
so i get sick of the miss at idle and i decide to see if the plugs are the problem. find that in one cylinder the tip is completly broken off, with a piece of the porcelain also gone.
i put a new set of tr6's in and start it, still idles with a tad of a miss, and a distinct tapping which sounds like an exhaust leak (was happening since the plug broke on the pass). the tapping is intermittent, like not every revolution of the engine, almost like a noisey lifter but it was never there before.
the car runs GOOD at WOT, no loss of power or anything that i can feel.
question= possible damage to one of the valves or the piston? im not really gonna worry too much about it unless it gets worse. seemed to get a lot better with the plug replaced but still a slight miss at idle.
i was thinking it took a little chip out of the side of a valve, which could be causing the ticking.
thoughts?
1= 145
2= 145
3= 115 (broken plug...)
didn't bother testing any more cylinders.. the car doesn't seem down on power, im probably just gonna keep driving/racing it for the time being. maybe pull that head and see if it is an easy fix or not..
think i'll hurt it more if i make more spray passes?
. You probley have cylinder going south. Maybe a burnt valve or hurt piston ring. It will only get worse from here... I would not spray it any more. You may be able to limp it around for alittle while.
Dave
1= 145
2= 145
.Trending Topics
i would just hate to yank the head and see piston damage, which is a big mess= yank the motor, pistons, machine work, etc....$$ im praying it is a valve.
thanks for the imput.
like mrr23 said, ran it's best spray time with 1/2 of a plug though
. can't complain about that. im praying it is a valve, which im optomistic that it is since the miss is pretty suttle and the compression isn't horribly low. just re-tested it and it is 110-115 still after kicking the crap out of it last night. im thinking i hurt the motor right when i hit the button- lean spike.. probably gonna knock some timing back at the lower rpms.
mine happened on the first nitrous pass, i made 3 more nitrous passes after it happened- since i thought it closed one of the gaps not burnt the tip of the plug off.
i actually upped the idle to 900rpms to help the miss be less noticable. hope for the best till the weather gets cold, then pull the head and assess the damage
