Spraying through shifts
Site URL: http://www.myls1.com
Description: Cool site, facebook style.
i had the spray cut off like 50-75rpms before the shift point. the et. that i've gained was soo minimal that it isn't worth it to spray it through the shifts on the 4l60e.
my setup DID take a ton of bottles/passes/tuning time and i have hptuners to adjust the shift points. it is worth it to save the trans though imho. like i said once it is tuned in and is REALLY close to the shift point but it still cuts off you are good. i did it by mph and just lowered it down till you hardly felt the nitrous shut off ans then it would shift. like .5 seconds the nitrous would shut off before it shifted.
btw msd digital window switch set at 6k and shift points were like 6050-6075 according to the logs. you cannot just set the shift points at that because you'll never actually see it shift at that rpm you gotta do it by mph, trial and error till you get it right on the ragged edge.
jmho..
that said, i spray through my shifts, and my 4L60E is starting to slip again...might be time for more drastic measures......
But to be honest I'm not running a big shot of juice either, as my system is rated at the flywheel.
Still, everyone and their brother is telling me I'm crazy not to run a ws. I guess time will tell whether I'm an idiot for jucin thru the shift's.
