Might be adding nitrous later.. Need imput.
Old Dec 15, 2006 | 11:13 AM
VenomInside's Avatar
Default Might be adding nitrous later.. Need imput.
Mods listed below.
I will be upgrading my cam to the one listed in the mods list. After that i want to see what i will run. My best on DR's is 11.9x with a 1.74 60". If i were to add maybe a 75 or 100 shot what do you think i can run?
MODS
Mods:
Mac Filter
Hooker Cat-back
Hooker O/R Y
Hooker comp LT's (EGR Delete)
Comp Cam (.588/.581 , .228/.222 114.5LSA) OLD CAM
Comp Cam (231 237 .589 .595 112LSA) NEW CAM
Vig 3600 Stall
Ls6 Intake
Lid
Eibach Springs
Bilstein Struts/shocks
Car made 380rwhp/379rwtq (w/ before cam)
Old Dec 17, 2006 | 04:02 PM
SPLATT's Avatar
with that cam and a healthy 100 shot id say youd be pretty deep into the 11s, enviroment permitting.
Old Dec 17, 2006 | 09:08 PM
john563's Avatar
do you think your rear end will hold?Im cammed and heads will be here in the next few days and im an A4.Im thinking Ill be around 395-400 rwhp(small cam)My wife is buying me a Harris N20 kit for christmas and was wondering if I can do a 75shot and not worry about the rear.what do you guys think?sorry to hijack this thread
Old Dec 17, 2006 | 09:12 PM
CAT3's Avatar
Restricted User
Rearends break most the time from hooking on the line. If you walk it out the hole then squeeze into it you should be fine. I went thru 2 stock rears, and finally went to a 9". A4 for a while, then went to A3 just before the 2nd stocker blew, and I always sprayed out the hole, hooking to a decent 1.4-1.5 short and fordloads of passes.
Old Dec 17, 2006 | 09:37 PM
john563's Avatar
not that I condone street racing or anything like that,but lets say im driving with it armed,but not at wot and floor it to pass someone I should be okay?I dont plan on using it from a dead stop until i get a 9inch and if i do use it at the track(on the 10 bolt) ill set it up on a 1second delay.Will the 10 bolt hold in these types oh situations til I get the 9 inch?
Old Dec 17, 2006 | 10:13 PM
LS1SpeedAddict's Avatar
low 11s high 10s with a 12bolt and good slicks. I have very simmilar mods and I plan on running 10s on a hundred shot. With some good suspension mods and a few weight reductions you sould be mid 11s without the spray.
Old Dec 18, 2006 | 10:43 AM
Sweet!
Old Dec 18, 2006 | 12:12 PM
CAT3's Avatar
Restricted User
Of course if it were to be assidently sprayed from a roll you should be fine for quite some time.
