Nitrous setup, what gears
Now here's my question. I'm still running the stock 10 bolt, which I don't think will last longer, but I gotta reward it for not breaking yet.
I know this should probably go in the gears section, but I figure who to know best than the guys that have the knowledge with the nitrous
I've thought long and hard about it. I was initially set on 4.10's before the idea of nitrous came about. Now, would 4.10's be too big to get trhough the traps. I know there are very many variables to it IE, how aggressive a setup, where ur limiter is set at, how tall a tire. But generally speaking, should a 4.10 be the answer...or go with a rear with a 3.90 option, or just stick 373
generally speaking imho with a 3800 stalled auto, cam, 26" tire, a 3.55 gear is PUSHING it on the juice! with my 2.73's i was at like 5800rpms crossing the line in 3rd gear! hell i might go even lower like 3.25's so i don't have to step up in tire size.. i like keeping the stock wheels no matter what the sacrifices.
a 4.10 on the juice= probably need a 30" tire and still be at max rpms crossing the traps.
I'm running 4.10s now and probably start with a 100 shot next season working up to a 150. Limiter is at 6800, running a 26" slick which probably grows a hair on the big end. Hopefully I'm not going to be running out of gear, but not sure. Figure it should be trapping 125-127 I'd hope on the 100 shot. Never bothered to watch and see what I'm crossing the traps at now, d'oh.
if you go with a 9" rear the gear changes are much easier to do vs. a 12 bolt. or so i've heard.
when you are ready to purchase things call harris speed works, they will hook you up and answer all of your questions. also close- right in warminster pa.
Still we've gotten a bit off topic, but I'm glad as it answered a few questions I had anyways.
So, what gearing should I look to run
