Nitrous help
Old Dec 16, 2006 | 09:34 AM
mdacton's Avatar
Default Nitrous help
Just bought a wet kit from HSW
car is a lt1 fresh motor with 40 passes th350 w/4500 stall and 4.57 gear with a 28"
If I try to spray a 75-100 shot do you think that converter will flash too hi?
This is also my first time sprayiung anything I have done lots of searching and plan on running all the safety items and a window switch, Just don't want any big surprises
Old Dec 16, 2006 | 11:58 AM
98redorangeta's Avatar
Well first too high is a relative term. Is the converter built for nitrous i am assuming not? A 75-100 shot shouldent be too much of a change but again thats relative it depends on you power band most would pick a smaller converter with nitrous though.
Old Dec 16, 2006 | 12:18 PM
mdacton's Avatar
the converter can handle the nitrous but when it was selected for the car i had never concidered spraying it.
Btw the car makes less then 400hp at the wheels
