Nitrous pressure/flow regulator from ZEX
Robert
Edit: Here is a thread on this issue. Read the last post, this is from a guy from NOS.
https://ls1tech.com/forums/showthrea...rous+regulator
Her's another for more insight.
Robert
Yeah...the question really is wether it will actually flow the large shots while clamping down on the pressure. They say this will flow up to 500 hp worth of juice while doing its regulating duties....which is pretty damn incredible.
This has been around for over a year now. I have a motorcycle customer that runs one that was released from the original designer. However the motorcycle units would not flow as much. On the bikes this may be a great device for the fact there bottles are so small and pressure drop is great. Not to mention most bikes are fighting amp draw problems and they can not leave there bottle hetaer on while waiting in the stageing lanes. With this unit you can adjust down the over all bottle pressure and tune your system for x amount.
Im not real sure how I feel about these in the car world because we use larger flow rates for bigger hp numbers.
If the flow regulaters expand inside and then shrink back down this will cause a phase change. However so does the inline filters and inline remote bottle openers. This normaly causes a flow restriction as well and will change the over all tune up.
There are many average street cars running the inline filters and some running the inline openers as well.
So the question here should be this..
Does the phase change seem to be more critical for larger hp shots?
Im going to think about this alittle more....
Dave
Im here. I just have not had much time for the web sites lately. We have been really busy...
Dave
Dave
Robert
...unless this nitrous regulator is being built from cheap parts.
Now, I do wonder, why can't we all use SCUBA tanks and fill our bottles with 4000 psi of nitrous? Any good reasons? because I don't know. Safety? Of course we'd have a regulator making sure it doesn't hit the solenoid with 4000 psi!
Robert
