DynoTune Purge
Old Dec 28, 2006 | 11:16 PM
ProjectCamaro's Avatar
Default DynoTune Purge
Can someone post a picture of their DynoTune purge selenoid setup? I just want to be 110% sure I'm hooking it up correctly.
Thanks
Old Dec 29, 2006 | 01:40 AM
Robert56's Avatar
My old set-up from a few years ago. I hope it helps.
Robert
Old Dec 29, 2006 | 12:46 PM
Yes that does help.
Thank You!
Old Dec 30, 2006 | 08:16 PM
Anyone else?
Old Jan 1, 2007 | 04:46 PM
http://home.comcast.net/~weaver.robe...8/site1018.jpg
Robert
So the purge has a braided line coming off it? DynoTune sent me plastic lines.
Old Jan 1, 2007 | 05:26 PM
2002t/a06's Avatar
they sent me plastic lines too..
Old Jan 1, 2007 | 05:36 PM
TigerWoodsJr's Avatar
Yeah, the braided is prob from way back.... no need for more than plastic.
Old Jan 1, 2007 | 05:40 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Robert,
Nice Pic - Thank you!
Yes tubing comes with the purge - Robert changed his. Of the hundred plus we sell every month 95% of the guys go with tubing with great results.
Typically the guys that go with the braided do it for the look.
Hope this helps!
Dean
Old Jan 1, 2007 | 06:34 PM
69z-28's Avatar
there are no other fittings needed for the purge setup correct? everything is included and it just goes inline between the bottles line and the nitrous noid correct?
Old Jan 1, 2007 | 06:39 PM
Robert56's Avatar
Yea, I added the braided for the looks thing, about 20inches worth. Then it does go to plastic tubing where it's not seen. Plastic is fine for open ended applications where bottle type pressures are not seen. I also used the Dyno Tune gauge adapter in SS, and polished it, again for the looks. DT noid base is also polished.
Robert
Old Jan 1, 2007 | 07:03 PM
Originally Posted by DynotuneN2O
Robert,
Hope this helps!
Dean
Ok I bought the dual exit purge as well. It only came with one tube, am I suppose to cut it in half or do I hook up the T fitting right to the selonoid?
Old Jan 2, 2007 | 07:03 AM
LS1TECH Sponsor
69-z28, Yes you are correct - everything you need is included! If you want the stainless adapter shown just let us know as we have switched to a blue swivel adapter. Feedback is the customers prefer the swivel adapter. Yes, we need to update the pic.
ProjectCamaro, Yes you want to cut the line we supplied. We provide it as one as many customers depending on their routing application do not need both lines the exact same length. This gives you the option for a custom routing.
Dean
Old Jan 2, 2007 | 10:30 PM
Robert56's Avatar
Dean
Swivel is good, however, I found a good way to make the static SS version work with placing outlets where you want them. I take the MPT x M/JIC fitting and tighten it into the adapter first, then screw the mpt end into the noid with lock tight. You can get it exactly where you want it this way, and no leaks. So, it's a good option if you want to stick with the SS one (is there a ss swivel?).
Robert
Old Jan 3, 2007 | 05:33 AM
Beer99C5's Avatar
I am a swivel fan, I use one on the Mainline in conjunction with the 860 Wingnut, makes bottle changes a breeze with no wrenches, gives you 2 additional bottle ports (I use one for the remote pressure guage, it stays on the mainline so works with both my bottles).
I will get a better pic but here is one of the swivel and the wingnut.
