Best oil
Old Dec 30, 2006 | 04:55 PM
courtneyh28's Avatar
Default Best oil
I have a 2002 ws6 with 18000 mile on it. i have lid,exhaust and i am installing a 100 shot wet kit.
WHAT IS A GOOD OIL TO USE WHEN RUNNING NITROUS.
Old Dec 30, 2006 | 05:15 PM
cjg454ss's Avatar
i run mobile 1 synthetic 10w30
Old Dec 30, 2006 | 06:55 PM
CAT3's Avatar
Restricted User
Whatever oil is good for NA or you like, just change it more frequently. I changed mine every month when: I sprayed 12-15x a weekend every weekend of the month.
Old Dec 30, 2006 | 08:36 PM
onephatZ28's Avatar
I swear by royal purple. I love it.
Old Dec 30, 2006 | 10:51 PM
Blk97WS6's Avatar
id go with motor oil
Like posted above, anything used for daily driving will be fine for nitrous
I personally use M1 5w30
Old Dec 31, 2006 | 07:44 PM
Thanks
I was going to use 0-30 german castrol But i was told it was to thin.
Old Dec 31, 2006 | 09:35 PM
Loudmouth LS1's Avatar
I just run regular pennzoil or valvoline HD40, but I am spraying a large shot and change it very often (which is why I stopped using synthetic, **** is too expensive to change all the time)! I used to run Mobil 1 0-40 though when I had the stock bottom motor in the car and was only spraying a small shot.
Old Jan 1, 2007 | 11:22 AM
=ZoomZ='s Avatar
If you use a good quality oil i dont think it matters who makes it as long as you change the oil often .
When i see the clarity of the oil go away i change it .
Castrol Syntech blend 10w30 here .
Old Jan 1, 2007 | 11:30 AM
blacktransam's Avatar
mobil 1 0w40 here.. pressures are awesome and i change every 3-5 k miles.. all my oil analysis are golden..
Old Jan 1, 2007 | 01:49 PM
Thanks guys
Old Jan 1, 2007 | 02:46 PM
GM Muscle's Avatar
I used to use M1 5W30 but the car would burn through a qt after a day at the track. Switched to M1 0W40, stopped burning oil but my oil analysis' were showing alot more bearing wear. Then I switched to Amsoil 5W40 and everything is good.
Old Jan 2, 2007 | 10:06 AM
great421's Avatar
Default Wal-Mart
OK, my brother pulled me (kicking and screaming) into Wal-Mart (I cannot stand the toothless wonders / customers that W/M attracts!) for oil; that's where he'd pick up a 5 quart container of M1. He's been using M1 exclusively on his 04 GTO. I was gonna' get a jug too for my 96 Formula, but there was also some brand new Valvoline or Pennzoil "Platinum" full synthetic oil there for less than $19 – we picked up 2 jugs and 2 filters.
After running that stuff for about 2 weeks my brother mentioned this mileage increased 2 MPG! This was last fall, and he's seen a consistent 2 mpg increase in his mileage since he switiched.
FYI – Cheaper full synthetic oil and better gas mileage – who could ask for more!
MLE
Old Jan 2, 2007 | 10:11 AM
TX_SS's Avatar
Originally Posted by courtneyh28
Thanks
no.. 0w-30 german castrol is not too thin.. best oil out there as far as oil analysis tells us.
Old Jan 3, 2007 | 08:39 PM
Thanks again
