NPT/AN question
Old Jan 8, 2007 | 01:40 PM
dementia's Avatar
Default NPT/AN question
Can anyone define/describe what the difference is? I haven't started the install of my kit yet but I'm reading through the instructions and have no clue what NPT or AN means. Also just to clarify, I'm supposed to use teflon paste on the NPT fittings? Where are all of the fittings that require the paste?
Old Jan 8, 2007 | 02:04 PM
Beer99C5's Avatar
Picture with what each end is (brought to you by Summit, text added by Me )
Old Jan 8, 2007 | 02:07 PM
Robert56's Avatar
The AN end uses a tapered seat interference fit for sealing and thus no sealer needed. The NPT end uses interfrence fit in the threads, but is lacking in sealing ability, so using a teflon paste is best.
Robert
Old Jan 8, 2007 | 02:10 PM
dementia's Avatar
Thanks a bunch
Old Jan 8, 2007 | 03:22 PM
Matt@HSW's Avatar
Just like Beer said, or look on page 12 of your user manual for a picture.
Matt
Old Jan 8, 2007 | 05:27 PM
dementia's Avatar
lol k wow how did i miss that!!! thanks Matt
Old Jan 8, 2007 | 08:46 PM
WheelsUp84z's Avatar
and one quick thing, make sure you use the paste on that stuff and not the tape, it can clog the noids up and cause failure (newbe mistake by me) but that was 4 years ago and im a lot wiser now
Old Jan 9, 2007 | 09:58 AM
Matt@HSW's Avatar
It happens lol. You’re doing it the right way, by starting off with reading the manual. Go over it once or twice and if you have any other questions ask, it makes the install go much smoother!
Matt
Old Jan 9, 2007 | 11:04 AM
dementia's Avatar
Yea thanks, that was the plan. Did you guys get a chance to send out that T fitting?
Old Jan 9, 2007 | 01:26 PM
Matt@HSW's Avatar
Yup, should have a tracking number in your email, went out yesterday.
Matt
Old Jan 9, 2007 | 01:36 PM
dementia's Avatar
Thanks I appreciate it. I did get the tracking number. I didnt realize it was for the T fitting, i thought it was just the last tracking from before i got my dry kit. You guys work fast. Thanks again.
Old Jan 9, 2007 | 06:14 PM
dementia's Avatar
Guess I might as well ask in this thread.
I went to a few different automotive stores looking for teflon paste and no one really knew anything about it. They all just tried to get me to buy the tape. The closest thing I could find is this Permatex High Temp Thread Sealant. Is this the stuff I need?
Old Jan 9, 2007 | 07:48 PM
Matt@HSW's Avatar
They should have it at AutoZone/Advance Auto in the sealant section (or even a Sears will have it). If you want you can use some red loctite on the NPT threads if you can't find the Teflon paste.
Matt
Old Jan 9, 2007 | 10:04 PM
Robert56's Avatar
The Permatex brand is named SEALS PIPE, which I use. Just look for pipe sealant with teflon, in a paste mix, many brands. Or like Ray said, use lock tight.
Robert
Old Jan 9, 2007 | 10:56 PM
dementia's Avatar
Hmmm ok, the one I picked up is named THREAD SEALANT but I dont see teflon anywhere. I'll go back tomorrow and see if I can get a refund or swap it out for the Seals Pipe one if they have it. I'd like to keep away from locktite as I dont want it stuck in any particular configuration just in case I decide to switch it up later.
Old Jan 10, 2007 | 08:43 AM
=ZoomZ='s Avatar
Ive been using locktite 271 on NPT fittings for about 20 years.
Good stuff for an instant locked seal in cold temps applications.
Old Jan 10, 2007 | 09:16 AM
Matt@HSW's Avatar
I felt the same way for a long time, but it gives a very good seal on the first go around. The changes are slim that you would have to take one of the NPT to AN fittings out of the base of the solenoid, but if you did have to it really isn't that hard. A vise and a wrench and it'll come apart, haven’t had to heat one up yet (knock on wood).
Matt
