What nitrous kit for LT1(stock for now)
I have a stock LT1 with full exhaust. I wanna get a 150 shot kit, but i wanna run a 100 shot(can i do that W/a 150 shot kit?)while the motor is stock. should i go with nitrous express? wet shot would be the best? what else should i get for the kit?also where is everyone getting there kit from? THANKS
Guest
Posts: n/a
NX makes a very quality system. Their Single Nozzle system is adjustable form 35-150shot so you can spray a 100 shot no problem. Being that it is a completely stock motor I wouldn't suggest you go over a 100 shot unless you upgrade the intank pump. Aside form the NX system we have our own Nitrous Outlet single nozzle System as well. Ours is also a very high quality system that is also adjustable from 35-150 shot. Both systems can produce up to 250 extra horsepower if you wanted to go higher down the road. The only thing that you will need would be an SHO hose. With you being an LT1 you have two options that you can go. You can go with a traditional Digital window switch or you can go with the Mallory 685 unit which encompasses an Ignition box, Timing retard, and window Switch in one unit. Accessory wise I you defiantly get some sort of window switch and get a FPSS ( Fuel Pressure Safety Switch). IF you want all the major accessories then I would suggest you get a GenX2 which includes Bottle Heater, Pressure Gauge, Fuel Pressure Safety Switch, Blow down Fitting & Tube, Purge Valve.
-Chris
-Chris
-Chris
-Chris
