Intake Pics on car
Old Jan 11, 2007 | 11:37 PM
st30thz4's Avatar
Default Intake Pics on car
What do you think??
Old Jan 11, 2007 | 11:42 PM
Robert56's Avatar
Very nice, great job. I like the blue hose, we use a lot of the blue at work.
Robert
Old Jan 11, 2007 | 11:49 PM
sidewayz28's Avatar
direct port?
Old Jan 11, 2007 | 11:50 PM
sidewayz28's Avatar
AND how the hell is that engine bay so clean? when you remove the AC condensor does the radiator fit in just fine w/out the condensor there? or do u need some kind of dif brackets?
Old Jan 11, 2007 | 11:59 PM
st30thz4's Avatar
the condensor actually attaches to the radiator, so it still fits perfect with no brackets.
Old Jan 12, 2007 | 12:13 AM
sidewayz28's Avatar
oh nice! off topic, but do you know the belt size you need when you delete the AC? during my head/intake swap i cracked the hard line that goes into the condensor, so might as well just take the ac off and put her on a diet ! but that engine bay looks amazing! what kinda nitrous set up is that? NX direct port?
Old Jan 12, 2007 | 12:40 AM
PlatnumStatuz's Avatar
Looks nice, that manifold/tb sure looks clean. What did you use to bend your lines?
Old Jan 12, 2007 | 05:44 AM
cakweems's Avatar
That looks really good you did a good job.
Old Jan 12, 2007 | 07:00 AM
NHRATA01's Avatar
There's a seperate belt for the A/C compressor. So just yank it off, the rest of the serpentine system stays the same.
Old Jan 12, 2007 | 07:58 AM
TN94Z's Avatar
Very nice. Nice numbers too!!
Old Jan 12, 2007 | 08:02 AM
Slow Z28's Avatar
looks awesome!!!!
i've used the blue pushlock hose, but the track techs have since said that it isn't a legal hose. that it should be braided line.
Old Jan 12, 2007 | 08:29 AM
Z284U2TRY's Avatar
Not digging the hose. Why do i not see any noids on the direct port?
Old Jan 12, 2007 | 10:06 AM
Todd157k's Avatar
They must be hidden so no one knows you have Nitrous!
Looks really nice. Is that a return spring (?) on the radiator shroud?
Old Jan 12, 2007 | 10:11 AM
Nitro Dave's Nitrous Outlet's Avatar
Good job.. Looks nice.
Dave
Old Jan 12, 2007 | 10:53 AM
David Tannenbaum's Avatar
Where are all of the wires? I know about the wire mods but you don't have anything showing...Help us out....No A/C is not an option here in Florida but WOW!! I don't think I have seen a bay that clean before without the valve cover shrouds.
Old Jan 12, 2007 | 11:20 AM
stealth71's Avatar
Anymore pics of your fuel pressure regulator setup? I am doing a similar setup on my Chevelle LS1 swap w/ Aeroquip socketless. Is that -8AN?
Where is the heat shielding from?
Looking good.
Old Jan 12, 2007 | 01:13 PM
TNTramair's Avatar
man, i was just lookin at that same thing...lol hey, whatever works!!
nice set up!!
Old Jan 12, 2007 | 01:40 PM
Mike00ss's Avatar
Looks Very nice!
Old Jan 12, 2007 | 02:41 PM
st30thz4's Avatar
Jesse Coulter did the work on the nitrous lines, I bought it from Apachedrill on the form. Yes thats a return spring for the throttle body(one of those great Fast pieces). All of my wires are still in the factory loom. The main feed line for fuel is -10 and the return is the same. The lines from the y-block to the fuel rails is -8 and from the fuel rails to the regulator is -8 also. Ill take some pics tonight and post them up. Thanks for all of the compliments. I try to keep it clean.
Old Jan 12, 2007 | 04:33 PM
Slow Z28's Avatar
you know what...
that's an awesome idea...
on my last TB, the return spring came undone and stuck the car WOT at the end of the 1/4...
i really think that was part of the reason it spun a rod bearing.
