Fast Intake With N2o
Old Jan 18, 2007 | 10:07 PM
bird2002's Avatar
Default Fast Intake With N2o
Is anyone using a fast intake, I know it says it has integrated nitrous bungs. I was wondering if it was direct port or how exactly that works. If someone could explain the setup to me that would be awesome. Thanks.
Old Jan 19, 2007 | 06:33 AM
TNTramair's Avatar
it has the ports to drill and tap holes for knozzles to be used in a direct port. but you can use the intake which ever way you want..DP..or the conventional knozzle set up.
dont be sold on the burst disks though.
Old Jan 19, 2007 | 08:57 AM
NitrousDirect's Avatar
you can also use that with the 90mm plate kit we offer, it's a sweet setup
90mm nitrous plate kit
also available in dual stage, and or just the plate as well...
Old Jan 19, 2007 | 10:53 AM
Nitro Dave's Nitrous Outlet's Avatar
Here is a good pic to show what it is...
If you look where the nozzles go into the directport there are raised bungs made with the intake. This is a dedicated place to place the nozzle. You will have to drill and tap the intake in this area and screw your nozzle in.
Old Jan 20, 2007 | 02:54 PM
Lightning's Avatar
^That is a thing of beauty right there!!!
Old Jan 20, 2007 | 03:35 PM
SmaknaSS's Avatar
That it is but you should see the other setup's he sells!! like the black widow and the money maker!!
Old Jan 21, 2007 | 04:46 PM
chris.shea's Avatar
you dont see anything on the moneymaker but yea dave sure makes some sexy *** directports.
Old Jan 21, 2007 | 10:01 PM
bird2002's Avatar
i see, thanx
Old Jan 27, 2007 | 07:43 PM
Randy WS6's Avatar
Heres my N.O.S. Pro fogger I done my self.
