What head gaskets?
Old Jan 29, 2007 | 04:03 PM
slowredz's Avatar
Default What head gaskets?
What is the best gasket for a car making around 700-750 rwhp? Spraying a 250-300 shot with heads studs Thanks in advance
slowredz's Avatar
Regular LS1 motor with ported LS6 style heads BTW...
Old Jan 29, 2007 | 05:22 PM
V6 Bird's Avatar
Hey man. GM MLS gaskets.
If you want the heads to stay on the car, get me the heads and Ill have Chris o-ring them for you to work with the MLS gaskets. I think its like 150-250 bucks to have it down. BUt you wont pop a gasket for sure. Then you could go run Mark in True street and bust his *** cause your car will stay together
Old Jan 29, 2007 | 11:00 PM
NEVR2ND's Avatar
Sce Ics Titan
Old Jan 30, 2007 | 01:11 AM
Happy Camper's Avatar
Originally Posted by NEVR2ND
Sce Ics Titan
They work good but sometimes are hard to seal Cometic seem to be a good choice.
Old Jan 30, 2007 | 08:54 AM
NEVR2ND's Avatar
Use some copper spray on them next time, just like people have to do with Cometics.
Old Jan 30, 2007 | 12:09 PM
next's Avatar
I've tried them all and MLS would be my first choice with Cometics closely following. I've used the SCE stuff and even with sealer they are prone to problems.
V6Bird - have you guys run an MLS with an o-ring and had success?
Old Jan 30, 2007 | 12:11 PM
V6 Bird's Avatar
Yes. Its very similar to what Ray uses for his 24 valve Dodge Cummins heads. Its basically a matter of how far you set them in the head.
BTW, this cummins head I speak of is 6G!!!!!!
But its the same head thats in use on the worlds fastest pro stock diesel they built the engine for. Its some pretty wicked ****.
Old Jan 30, 2007 | 01:05 PM
next's Avatar
When you o-ring with the MLS does it eliminate seeping like the coppers are prone to?
Old Jan 30, 2007 | 01:17 PM
Juiced's Avatar
I've neaver heard of anyone running MLS gaskets and 0-rings.
Old Jan 30, 2007 | 01:29 PM
V6 Bird's Avatar
If done correctly yes...
If youve never heard of anyone doing it, that doesnt mean it cant be done..
Ohio Boys are doing the same thing!!! But with boost.
Old Jan 30, 2007 | 01:37 PM
next's Avatar
Good info. Keep me updated on any nitrous applications you guys try with this.
Old Jan 30, 2007 | 02:21 PM
V6 Bird's Avatar
The motor thats in the dyno section actually has stock size studs and Fel-Pro MLS gaskets. No O-ring Its making ~700 just on motor. The goal is to make 1000 on the engine dyno and crate it up. Just waiting on an alternator setup to try one more time to get enough voltage at the coil packs. If thats not it, I know hes gonna say F it and order the front mounted distributor setup.
Old Jan 30, 2007 | 04:43 PM
red90cobra's Avatar
when i lift the heads on my car i'll be calling you mike, gonna need those o rings.
Old Jan 30, 2007 | 04:44 PM
red90cobra's Avatar
i was gonna say the boost guys are doing it
Old Jan 30, 2007 | 09:50 PM
V6 Bird's Avatar
Build em right and they will come. The 372 ci motor results have just been upped even more. 724 hp and counting. What you know about that?????
