calling all fjo guys
Old Feb 8, 2007 | 10:13 PM
1320 killer's Avatar
Default calling all fjo guys
I'm using my fjo mini controller for the first time in a couple of hours. In the direction booklet it says that the rpm multiplier should be set at divided by 4. but from what I have been told id that it should be set at divided by 2 because of the sparks per revolution on the ls1. someone please help. thanks to all in advance who can help
Old Feb 8, 2007 | 10:50 PM
SmaknaSS's Avatar
I set mine for divide by 2 with the signal input coming from the tach signal. I had the same problem as you when I first set it up.
Old Feb 9, 2007 | 12:08 AM
thanks, I'm gonna race a 03' cobra tonight with a kenne bell and all the bolt ons. I will record it and post it up. thanks again
Old Feb 9, 2007 | 06:46 AM
stealth71's Avatar
What FJO are you running? I just ordered their dual channel wideband. Do you like yours?
Old Feb 9, 2007 | 07:27 AM
Sigforty's Avatar
Set it like a 4 cylinder. The LS uses a 4 cylinder tach input so any tachs or RPM based items need to be wired like you would for a 4 cylinder car.
Old Feb 9, 2007 | 10:31 AM
Johnny5's Avatar
I think I made a post a while ago about "FJO Progressive Controller Settings". If you seach I posted all the settings in there.
Found it: https://ls1tech.com/forums/showthrea...ight=FJO+Setup
Old Feb 9, 2007 | 10:52 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
If you are connecting to a coil ls1 use times 2, and if on the tach signal divide by 2. this is becuase the tach signal is on ls1 it looks like a 4cylinder signal..
Old Feb 10, 2007 | 11:18 AM
Thanks for everyones input. The controller is getting the signal from the computer so it should be set at divided by 2 and it works great. I am very happy with my controller. I was a little sketchy at first but once you play with the program a little I'm very happy with it.
johnny5 thanks for the link, I have not looked at it yet but I am sure that I will find a lot of new information. Thanks again
