14168nos bottle opener problem
Old Feb 11, 2007 | 06:00 PM
2thousand2's Avatar
Default 14168nos bottle opener problem
I have a brand new NOS bottle opener (the one that turns the ****) and when purging the lines clear the opener will rotate open and then closed on and off...refilling the line. Nitrous isn't the cheapest and the opener was not cheap either. Kyle at NOS recommended that I raise the opener off the **** just a little bit. I have tried it several ways and it just keeps opening and closing on its own (when purging the line out).
Has anyone else had this problem?
Thanks for any suggestions!!!
Old Feb 12, 2007 | 11:50 PM
2thousand2's Avatar
Ttt!!!
Old Feb 13, 2007 | 09:39 AM
Kyle@NOS's Avatar
LS1TECH Sponsor
I want to make sure that I'm understanding correctly. When the opener is off/closed and you purge the system the opener cycles open then immediately closes. Is this correct?
Can you send me a schematic or a description of the wiring at the switches?
Kyle
Old Feb 13, 2007 | 06:49 PM
2thousand2's Avatar
Kyle
Correct. My switch has a ground, signal on (blue to control box), and a + switched 12v source. I unplugged the blue wire and had a friend keep pushing the purge (on, off, on, off, etc) and even with the blue (signal) wire unplugged it will eventually cycle the opener on then off. I put a voltage meter on my signal wire from the switch and am getting no voltage jumps or anything. I think the control box may be bad. My ground for the box ties in with the ground for my heated bottle bracket. My constant battery voltage wire (for the control box) is direct from the battery on its own wire. Something is making the opener spin open then immediately closed when tapping the purge button.
Old Feb 14, 2007 | 08:26 AM
Kyle@NOS's Avatar
LS1TECH Sponsor
Sounds like there might be something wrong in the box. Send it to me and I will get it checked out and fixed or replaced.
Kyle
Send it to:
NOS Tech Service
ATTN: KYLE
1801 Russellville Rd.
Bowling Green, KY 42101
Old Feb 14, 2007 | 02:25 PM
Nitro Dave's Nitrous Outlet's Avatar
Kyle is the man... He will get you fixed up.... He takes care of our Needs all the time.
Dave
Old Feb 14, 2007 | 05:53 PM
2thousand2's Avatar
Kyle
Send it to:
NOS Tech Service
ATTN: KYLE
Thank you Kyle I will send it out Thursday.
Old Feb 14, 2007 | 05:57 PM
2thousand2's Avatar
Dave
Yes, thanks to his badassness I have this upgraded opener compared to the solenoid style I originally ordered from Chris at Nitro Daves. I just need one that works now LOL
Old Feb 15, 2007 | 10:20 AM
Kyle@NOS's Avatar
LS1TECH Sponsor
Dave
Thanks for the complements!!!
Nick, I will try to get the controller back to you as soon as I can.
Kyle
Old Feb 15, 2007 | 10:30 AM
2thousand2's Avatar
Kyle
shipping it out today, thanks!!!!!!!
Old Feb 16, 2007 | 09:54 AM
ohh no. You are having hell huh? I was not aware you wree having issues. It looks like you are in good hands and Kyle is taking care of you. He is the one that swaped out the inline one for us as well. I am confident he will get you fixed up. Sorry for the troubles.
Dave
Old Feb 16, 2007 | 06:17 PM
2thousand2's Avatar
Dave
Yeah I have had ran into problem after problem getting this car setup. One thing I do like is the 593 ft lbs of torque on a 100 shot!!!! I have no doubts Kyle will get this fixed...I just think its crazy its been issue after issue!!!
I am hoping this control box is the problem. Its the only thing I can think of that can make the opener operate when there is a slight voltage drop/spike when hitting the purge. I even unplugged the blue control wire to make sure it wasn't the signal wire. There must be something in the box going wrong when the full battery wire is getting voltage differences (when hitting the purge).
Thanks for your great customer service every time I have called!!
Old Feb 16, 2007 | 06:18 PM
2thousand2's Avatar
Dave
Oh ya and Dave if you talk to Chris tell him to post up some pics of his car with the CCWs on it. He told me he would a LONG time ago LOL.
Old Mar 1, 2007 | 08:24 PM
2thousand2's Avatar
I believe everything is good now. I just installed the replacement control box (mine had a short in it) and it seems to be working.
Thanks Kyle for the great service!!
Old Mar 2, 2007 | 09:00 AM
Kyle@NOS's Avatar
LS1TECH Sponsor
Glad everything is working. What do you think of the new design and the LED?
I think you got the first one.
Kyle
Old Mar 2, 2007 | 06:51 PM
2thousand2's Avatar
Kyle
Its really nice!! It seems to keep better control/monitoring of the bottle opening and closing actions.
thanks again!!
Old Mar 2, 2007 | 08:52 PM
BOTTLEFEDLS1Z's Avatar
Mine is doing the same thing as Nicks. I wonder what the problem was/is?
Old Mar 5, 2007 | 10:51 AM
Kyle@NOS's Avatar
LS1TECH Sponsor
His had an internal short.
Is yours cycling when the system is purged?
Kyle
