250 whp shot, need advice
also what is the hp limit on a walbro fuel pump. i have a wideband to check but would just like to know when i would need to add a bigger pump a boosta pump.
If your serious about running that large of a shot, I'd get a dedicated fuel system and then you wouldn't have to worry about the fuel.
Is the N20 a wet or dry?
I would not spray that much on a stock piston let alone the bottom end
Car died finally when the owner was trying to chase down a vette that had a head start...they went well into 5th gear and he did not have enough octane to cover the extra load in 5th gear. He burnt detonated and burnt a valve and part of the head. Stock Bottom was actually ok.
It can be done...just have to watch the tune and use plenty of octane.
If you do that, I still think your on borrowed time. Honestly I don't know what to say. Dude, you could be fine and run a 250 for years, you just never know. Do you have the funds to rebuild a shortblock readily available? That should be the question. If you do then spray away and let us know how many bottles the motor took before it let go.....
i have the money, i was just wondering how big i could go. i might just swap out the pistons and rods for some forged ones and some arp bolts. whats the most guys are shooting on just swapped forged rods and pistons w apr bolts? 300? 400? shots
Robert
considered everything and went standalone thanks
I have a nos digital progressive. My thinking is if you can gradually bring the hit on then it would be like running FI. You see what the FI guys are doing with the stock stuff.
My dry hit (135rwhp) in dyno overlay was in dual stage, so you get the benifits of not beating the hell out of your noids, and still getting the progressive nature on the hit. Also, my peak tq was 503, same as turbo, and peak HP was 480, however it wasn't transfered that way?
Dyno Overlay N2o Dry vs Turbo vs stock
Robert
Robert
x2
