Switch question
Old Feb 28, 2007 | 07:50 PM
dementia's Avatar
Default Switch question
The switch that came with my kit (and the ones that I bought) have 3 prongs on the back. The directions to my HSW kit show what to do with each of these prongs. One goes to the micro switch, one to ground and another to 12+(12volt source?). The back of the switches that I bought are labeled Line, Load, Neutral. Am I correct in saying Line-micro switch. Load-12v source. Neutral-ground. ?
Also while I was digging around I found a few switches that might make for a cleaner install. The thing is with these though, they only have 2 prongs on the back. Can I use these?
Old Feb 28, 2007 | 07:54 PM
billybadd's Avatar
Line-12v, load-switch, other is ground.
Old Feb 28, 2007 | 11:32 PM
Todd157k's Avatar
You can use those switches provided they are rated for 10amps minimum. The downside is that the system is not "grounded" when not in use. It's just a safety precaution.
Old Mar 1, 2007 | 12:23 AM
dementia's Avatar
I'm not sure if they're able to handle that. Theres no markings on em whatsoever
Old Mar 1, 2007 | 02:39 AM
dementia's Avatar
anyone know of a site that has a bunch of switches? maybe i can find mine on there and look up the specs.
Old Mar 1, 2007 | 04:07 AM
99Daytona500's Avatar
Your local auto parts store and RadioShack both carry assortments of 12V switches. Be careful with some of the smaller narrow switches, those tend to wear out and break over time. Also look into buying a fuseable link for some of your connections, it wires in right before the switch and will blow in the event a switch shorts out, which I have seen happen and it fried an entire wire bundle. I recommend a trip to the auto parts store just to look around.
Old Mar 1, 2007 | 09:40 AM
Todd157k's Avatar
I found a bunch on ebay that are exactly like the ones used in Beer's panels. ( I now have a 'Beer' panel and added a switch instead of purge button). Just make sure of the current rating. Some switches just say "125v" which means nothing.
These
Or these
Or these
Or these Like Beer’s
Old Mar 1, 2007 | 06:52 PM
Beer99C5's Avatar
Walmart has 25 and 30 Amp Switches as well as any Auto parts store.
Old Mar 1, 2007 | 10:26 PM
Good call on that one Beer, I just remembered that Walmart has many of the same switches as the autoparts store but CHEAPER. Sometimes even $1 cheaper for a $4 switch.
