Finally hit a decent sized shot again!!!
Old Mar 5, 2007 | 11:00 AM
Noyzee's Avatar
8 second mod
Originally Posted by Loudmouth LS1
Thanks dude, how's urs comin along?
have not touched it since i rolled it to the end of my garage. winter here, snowmobile season!!!
i have got my plan tho, block is going to machine shop next week, rods and pistions to be ordered after that. throw it together, and go racing!!
it will be done by the end of april im sure.
racing here wont start till then, maybe even beginning of may. we'll see.
Old Mar 5, 2007 | 12:09 PM
Loudmouth LS1's Avatar
Originally Posted by ATVracr
Did you erase the other thread?
Get those limiters fixed and its going to roll out.
I'm going to be gun shy the next time out .... my last pass was on the bumper and it didnt end up pretty.
Yeah, for some reason I posted that post first, but my internet lost service and when it came back, I looked and it didn't post, so I made this one, but then a day later that one was there and I was like wtf, and didn't want two posts, so deleted it. I'll get them figured out, i'm thinkin I might cut the area out between the top hole and second hole and just make it a sliding adjustment and get it where it needs to be and crank it down real tight to keep it from moving, could that work? Cuz Madman said that they are exactly where he puts them, so he doesn't know why they're not givin me the right adjustments.
I got lucky that everything went smooth, i've had a few I had to let out of (or let out of cuz I was scared and still wasn't really used to drivin through something like that), but I still have the stock kmember on the car and that saved my ***!!!
Old Mar 5, 2007 | 12:10 PM
My bad, forgot you guys have winter!
Old Mar 5, 2007 | 12:15 PM
Noyzee's Avatar
8 second mod
hey, i make the best of it!!!!
i almost hit the bumper on my sled.
Old Mar 5, 2007 | 12:41 PM
That's awesome dude, I miss snowmobiling!!!!!!
Old Mar 5, 2007 | 12:44 PM
ATVracr's Avatar
I dont know about a sliding thing. I'm against the cable style limiter on my car because of stretch.
We bought the Madman kit and moved the Aarm mount out like I said and got a longer chain to make the adjustments smaller. The way he wants it one hole makes to much of a change for us.
His is the best set up but we like to make smaller changes.
I tried driving through it but when you shift and it just STAYS up there .... I had to let off
Good luck with it!
Old Mar 5, 2007 | 01:18 PM
Good luck with it!
I'll have to see if my buddy can cut it back out and reweld it for me, any pics of exactly where urs is so we have something to go off of? And i'm assuming you just get however long of a chain you need to put it at full extension when in the longest hole, right? Should I get a thicker chain, or same?
And yeah, guess that could be pretty bad if it just stays up there like that, although, so long as she's goin straight and ya still got two wheels on the ground it could probably work, ahahhaha!!!
Old Mar 5, 2007 | 03:13 PM
Slow Z28's Avatar
is it possible to adjust by chain AND the tabs? i've seen pics, but they are blocked here at work, so i'm thinking if you get a different chain that has a smaller length LINK, you could use that as "1/2" adjustments, and then the adjustments on the tabs as the FULL adjustments...
