How Hot is your Heater?
Old 03-07-2007 | 12:49 PM
BigDB's Avatar
Default How Hot is your Heater?
How hot do most of yalls heaters get and how long does it take? I have the NX unit with the transducer and it gets warm but not hot. Im wandering if i need to use a little bigger wire for power to the relay.
Old 03-07-2007 | 01:53 PM
02NBMWS6's Avatar
mine will burn your hand pretty good when its not attached to the bottle. when on the bottle it gets pretty warm. i used a 10 gauge wire and a relay for it.
the bottle really keeps it alot colder than it would be when it is unatached. ive suffered a mean burn from it when it was unattached
Old 03-07-2007 | 02:15 PM
860 Performance's Avatar
Should be fused 10awg directly to the battery
Old 03-07-2007 | 03:23 PM
BigDB's Avatar
I have a relay which uses direct battery and a switched power from my arming switch. ima redo the wires just in case, I dont think I used 10gauge
Old 03-07-2007 | 06:30 PM
sprydncamd ta's Avatar
i run the harris speed heater and it gets hot fast and stays that way because of the insulation materials used
