Thinking about jumping into the nitrous group...
any opinions or suggestions?
thanks
We carry many different dry systems to choose from. The Halo being my favorite. The good thing is that all of our dry systems come with 20ft main feed lines, large 300hp solenoids with purge port, 800hp bottle valve with dual ports,etc. So as you can see we did not get cheap on the quality side of things to keep build cost down.
What all is done to your car?
If your car is stock you should be fine with the stock injectors. If you have a cam you will need injectors. You may also need some computer tunning to adjust airfuel.
I would add a window switch and fuel pressure safety switch for safety.
Then a heater to controll bottle pressure.
A bottle gauge to know bottle pressure
And possibly a purge to purge air out of the main feed line.(optional not as needed as the rest on a dry kit)
Deffintly change your spark plugs to NGK tr6 plugs.
If you end up going with a Halo is comes with some of the acessories. It comes with the bottle gauge,fuel pressure safety switch,nhra fitting and blow down tube.
If we can answer any questions please feel free to hit one of us up.
Dave
I might see you this weekend if you go to savi ranch so we can talk about spray. I have decided to add some spray to my ride. But i will being getting a wet kit from Harris Speed Works.
thanks
It's a ton of fun but really addicting.
Robert
I have a basic idea of how this stuff works but i'm still a total newb!
https://ls1tech.com/forums/showthrea...ghlight=basics
Have fun dude!
