Why do i keep on melting spark plugs????????
Alex
Are you absolutely sure about the timeng? What are you using to retard or control timing?
Are you certain its a 150 shot? TNT is known to under rate the jets. It makes no difference what they call a set of jets...what comes out is what actually comes out.
Whats your rpm activation points and are you having massive TQ spikes due to low rpm activation? Even a 150 shot at 3000 rpm (especially from and under rated kit like a TNT) can induce detonation if it hits hard and fast.
Are you monitoring for knock?
Obviously you are experiancing detonation. Need to find the cause.
If you dont find any obvious things...take another 2 degrees out of timing and step up to 104 unleaded in the standalone.
NX Jeremy helped me dial mine in and I learned alot
If you are getting good AFRs out of BOTH sides and still melting plugs things are not well.
I would empty the main tank of your car and put 100 in there too.
Or maybe step up to 104 in the stand alone.
You could also get some plugs that are one more heat range colder. I believe NGK BP7EFS or som ething like that. There is a stiky in this section for plugs.
You cant be melting spark plugs and NOT getting knock??
I suspect your TNT kit is really spraying quite a bit more than the intended 150 shot. And at low rpms you are getting a small amount of detonation.
You have a few paramemters to change around to eliminate that.
Increase octane
further reduce timing
raise the rpm activation point closer to 3800-4000
go dual stage of say 80 at 3000 and then another 80 at 4500.
One - You must keep in mind that the wide band is only picking up the combined O2 ratio of the cylinders. If some are richer than others then it may even itself out once mixed in the exhaust. If you have an EGT meter it could tell you volumes about the cylinder it is measuring but it would require some not so pretty cosmetic work on the headers.
Two - Some cylinders create a stronger vacuum signal due in part to the manifold design and can be robbing other cylinders of the needed fuel.
Three - I see that you are running a ported head but am not sure if it is a 5.7 head or not. As such what is your static compression ratio? The reason that I ask is that 24 degrees overall doesn't really tell us much in that the N2O may require less timing up top where as you can get away with a little more in the lower RPM ranges depending on compression and cam profile.
Four - As stated I would be looking at fuel distribution. With the injectors that you have I would try adding some fuel to all of the cylinders and then work backwards. I would use nothing less than 110 octane to start with. Fouled plugs due to a rich condition are always easier on the mind and wallet than burnt ones are.
Five - A 150-hp shot on one system is not always the same as another. One reason for this is that some rate their gains at the wheels while others rate them at the flywheel. Having said this more octane, fuel and perhaps a little less timing would be in order for now. Then work your way up slowly and check your plugs after each change. Technology is a wonderful too but sometimes we must resort back to our roots to resolve certain issues. Pull those plugs and read them carefully!!!
Jim C.
In the past when we used a Dynojet to tune we would have to add 10-20% more fuel at the track.
The Mustang Dyno we use now is ALOT closer if not dead on most times.
Richen it up and try some TR7's , I would even take a few degrees of timing out.
You could always put a tr-9 plug in the car too, if you suspect the plugs are too hot and that's causing your problem put those in there, if it's a plug only isue, I bet thise won't do it.
I'm guessing you have a fuel pump going to hell, or the fuel filter is clogged, something like that. If you've been using the kit for a while and not having issues, and now it is, I'd be looking at the fuel side of things first.
Put the timing back to about 20 degrees too, you're better off starting out on the mild/safe side of things then doing what you are doing.
FWIW, we always set mine to around 11:1ish on the dyno back when i had a stalled auto because it would always lean out at the track under load.
