LT1 Solenoid Brackets
This solenoid bracket will mount off the top of the throttle body bolts. This unit will clear a stock hood with a little " finesse " you will have to either bend the bracket a little or clearence the hood bracing.
This solenoid bracket will bolt down using the front two fuel rail bolts.
If you are using a purge port design solenoid the bracket has enough room to mount the purge and gives enough room for the fuel and purge hook ups.Both units are instock and are ready to ship. They are currently not on the website but will be on there shortly. You can call you order in
( 1-866-648-7637 )
Thanks
-Chris
How in the hell does the purge solenoid fit in between there and one still retain access to the inside port on the fuel noid? It doesn't look like it can be done without a 90* fitting coming off the inside of the fuel noid.
This is gonna look great with my new LT1 plate from you all.
