Quick blow down tube question
Old Mar 25, 2007 | 02:42 PM
dementia's Avatar
Default Quick blow down tube question
Can you use braided steel (flexible) line as a blow down tube? I dont want to drill through my car and would like to route the blow down tube to the opposite side of the car and out the gromet under the spare tire.
Old Mar 25, 2007 | 03:32 PM
860 Performance's Avatar
yes you can, its -8AN.
One word of caution though- Make sure you use a bulkhead fitting where it goes though the floor. Dont just push it through a rubber grommet. The reason is if you ever pop a burst disc, the hose will whip like a fire hose, except more violent.
Vinny
Old Mar 25, 2007 | 03:36 PM
brad8266's Avatar
Vinny
Old Mar 25, 2007 | 06:43 PM
stealth71's Avatar
Good idea.
Old Mar 25, 2007 | 06:44 PM
camarokid94's Avatar
i did this looks trick too.
bottle in right rear. line bulkheaded nder spare tire so claen and much easier than that tube.
Old Mar 25, 2007 | 06:58 PM
Robert56's Avatar
Two blow downs going to a bulk head tee.
Robert
Old Mar 25, 2007 | 07:59 PM
mrdragster1970's Avatar
6 & 8 Second Club
We use steel braid blow downs. I had the 2 bottles into a Y then into a bulkhead at the floor. They made me run 2 lines 2 bulkheads, just so u know, some tracks might not like Roberts.
Old Mar 25, 2007 | 08:14 PM
dementia's Avatar
Awesome thanks for the replies guys. Where can I pick up one of these bulk heads? Any of our vendors carry them?
Old Mar 25, 2007 | 08:25 PM
http://www.nitrousoutlet.com/catalog...roduct_id=1116
~RedLineLs1~'s Avatar
Got mine from Napa.
Old Mar 25, 2007 | 10:55 PM
Ping King's Avatar
I used large -8 powersteering hose with stainless ends on it. I was worried about a rubber hose exploding inside the car, even if it does have stainless braid around it.
Old Mar 26, 2007 | 12:14 AM
Nitro Dave's Nitrous Outlet's Avatar
We carry all the hose and Earls fittings to help you with your install. Our sales guys also know there way around the fittings if you need guidence.
Dave
Old Mar 26, 2007 | 12:24 AM
dementia's Avatar
Awesome Dave. I'm planning on picking up a few goodies from ya in a few weeks. I might get these at the same time.
Old Mar 26, 2007 | 08:23 AM
Sounds good.
Dave
Old Mar 26, 2007 | 07:52 PM
Robert56's Avatar
Dave
pressure on the blow down really isn't much of a concern, reason: it's an open ended hose. That's how some kits get away with poly (plastic) lines after the noids-open ended. It is much tricker running braided though.
Robert
Old Mar 26, 2007 | 10:22 PM
oange ss's Avatar
Old Mar 27, 2007 | 04:46 AM
dementia's Avatar
Sweet thanks for the pix. Thats what I like to see. So I take it I'll still be stuck drilling a hole in the floorboard? O well I guess I can live with it.
Old Mar 27, 2007 | 07:07 AM
oange ss's Avatar
the hole is actually a factory drain hole, but i did have to enlarge it a little for the bulkhead fitting...
Old Mar 27, 2007 | 10:17 AM
Todd157k's Avatar
very clean. Looks good.
Old Mar 27, 2007 | 11:22 AM
oange ss's Avatar
thanks
