Best Ci Motor For Spray?
8 second mod
Originally Posted by ls1CANTU
should i go with a solid cam or stay hydrallic on my next spray motor?
right now its on my list, but $$ is an issue for me, so im sticking with hydrolic for now, but going solid would probably net atleast an extra 50 rwhp, and alow you to zing the motor higher which in turn alows you to run more gearing which in turn make for a faser car.
it isnt cheep, but is worth it
8 second mod
How much difference is from a hydrallic to a solid? about $1000-1500?
they you need to machine the heads for a better spring, then buy the better spring.
id say to look around the 2,000-2,500 range done right
